Question about Creative Labs Gigaworks S750 Computer Speakers
Fuse blows Hi, the 3.14 fuse keeps blowing, replaced faulty 470uf caps and it still blows the fuse, any ideas?
  • Anonymous Jul 31, 2008
    I have exactly the same problem, where do I find the Capacitor and driver IC to replace?
    Cheers
    Rich
  • malla12 Aug 31, 2008
    test
    Genius:
  • 1,554 Answers
Once the caps blow they usually take out the driver ic too.
check across your power to the amp with ohmmeter
when you find the issue it will drop to around 20 ohms in one direction.
Posted on Apr 26, 2008
Mackie profx12 fuse keep blow
Be sure the capacitor was replaced with the correct polarity?
in the beginning of my tech career I have replaced caps back words on accident. ..
Mar 06, 2015 | Mackie ProFX12 Professional Compact Mixer
2007 Honda NT700V Deauville headlight bulb keeps blowing
Hi, Ksivac if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chafed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/low beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Thread Headlights keep blowing out
why would keep blowing headlights
Honda NT700V Deauville Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
HONDA NT700V Owner Manual
Jul 20, 2011 | 2007 Honda NT700V Deauville
When turn on it blows the fuse
There must be a diode that is faulty in the power supply section mainly on of the rectifying diodes.
If you look closely at your board you will see four diodes that just after the fuse and befroe the Big capaictor(filter cap.) One of these four diodes must be faulty as the fuse keeps blowing. the diodes are responsible of current limitation drawback. So there must be current flowing back to the fuse that makes it keep blowing.
Check and replace. Good luck
Thanks for using Fixya.
G.
Jun 27, 2011 | Pioneer SX-205 Receiver
Wiper motor montora sport suv keeps blowing fuse
dis-connect wiper motor and replace fuse and try switching wiper motor on if fuse does not blow motor faulty and shorting out and causing fuse to blow.if still blows fuse must be a short in the wiring from wiper motor plug back to wiper motor switch.
wiper motor proberly faulty
May 01, 2011 | 1999 Mitsubishi Montero Sport
Beko wm5120s fuse keeps blowing.There is flash in the drum when it blows.any ideas?can only do a rinse,any other programs blow fuse.
Your element will be faulty. Remove both wires off the element. tape them up. Select the program that blowa the fuse and run. If not blowing, replace element.
May 27, 2010 | Washing Machines
Keep blowing fuses for the wipers, have replaced
Your wiper motor is about to go out, if it hasen already, wiper motor pulling to many amps will cause the fuse to blow.
Dec 09, 2009 | 2003 Hyundai Accent
1996 GMC 1500 Pickup. Keep blowing 20A ECM-B fuse. Replaced Ign Mod,Coil,Cap/Rotor & pickup. Any Ideas Out There? Afraid to go any futher...dont want to ruin these new parts!
if you keep blowing a fuse there's a good chance it's not a faulty part but a short in the main harness most likely under the dash where all the connectors tend to get brittle over time and short out constantly. also check the ecm connection there is a 60 pin type.
May 19, 2009 | GMC Sierra 1500 Cars & Trucks
Blows 4 amp fuse inside tv
the poer supply faulty. Isolate Horizontal output stage from the power supply and connect dummy load (like normal bulb same wattage as TV ) and test. before that pls check all component in power supply and replace and burnt parts spacialy diodes caps and power regulater ic as well
Jan 15, 2009 | Televison & Video
En7410 won't turn on
DONT WASTE YOUR TIME AND MONEY THE PCB(POWER CONTROL BOARD IS BAD YOU WILL BE BETTER OFF BUYING A NEW MONITOR)
IF you do find the power control board replacement and get it to work i think you would have better results spending the same amount of money on a new monitor with all new parts plus warranty
Jan 15, 2008 | Envision EN7410 17" LCD Monitor
Creative Labs Gigaworks S750 Computer Speakers Logo
373 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
