Question about Vacuums
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
  • sealsfam6 Jun 27, 2008
    my vacuum cleans but when the power head is on it smells like burnt rubber
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542493
Generic problem for all Vacuums
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 24, 2008
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
Runs, Smells like it is burning up
If it smells like burning rubber then it's possible that the belt is broken.
Feb 11, 2011 | Hoover U5753-900 WindTunnel Bagless...
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Vax mach 5 burning smell and revving loud
The revving/burning is because the belt is burning off and the power head motor is running without load...
Flip the carpet power head upside down on the rug and look for visible screws and screwdriver release slots on the bottom plate of the head.
When you remove the burned belt determine the cause. Will the brush roll freely or is it jammed with hair and fiber?. Clean the burned rubber from the motor shaft before replacing the broken belt, available at a vac specialty shop.
Sep 04, 2009 | Vacuums
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
WHEN I TURN ON UNIT IT SMELLS LIKE WHEN THE RUBBER BELT STOPS TURNING ON A SWEEPER. HOW DO GET TO THE MOTOR AREA?
Mosture has gotten into the motor. Take the bottom tank off and let the unit run for 30 seconds. It will dry out the compartment
May 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Vacuums Logo
345 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
