Question about Refrigerators
I need to find the defrost timer to encourage it to kick off. I've been told I can use a flat head screwdriver to make the adjustment, but I can't find where the screw is I'm supposed to be changing.
    President:
  • 1,218 Answers
Good day,
You don't adjust it. It's not adjustable. You use the screwdriver to turn the shaft clockwise until it is in the defrost mode.
Most are in the top section of the fresh food compartment, but on older models can be outside behind the front kickplate.
Without a make and model I connot tell the location of the control.
As well, some models use what are called an adaptive defrost control which is totally electronic and has no way of being mechanically advanced.
There are other parts to the defrost system that can fail. The main heater and defrost thermostat which are located on the cooling coil which is located behind the rear panel in the freezer section.
In any case one or more of the parts has failed, and for the machine to continue to defrost properly must be identified and replaced.
Posted on Jul 30, 2010
No cooling in refrigerator and freezer msd2456geq
It is possible that the defrost timer has failed while in defrost. The defrost timer can be found inside the control panel inside the fresh food compartment. The defrost timer is location number 13 in the photo=> HERE You can test the defrost timer by going through a small opening in the control panel or by opening the control panel and using a flat head screwdriver and turning the timer dial slowly clockwise until the compressor and fans restart. If this starts the refrigerator again then you will need to replace the timer because it is defective. I am here should you have questions, Sea Breeze
Your model uses a=> 68233-2 Defrost Timer
Sep 03, 2013 | Refrigerators
Gsh25jsxss
defrost timer is bad.
Dec 23, 2017 | Refrigerators
Freezer needs to be defrosted every 3 to 4 days
Let's Try turning the defrost timer clockwise slowly. 67001036 Defrost Timer The defrost timer is item location 12 in this photo HERE and there should be a hole with a plastic plug covering the hole that you place the screwdriver through. Turn timer with a flat head screwdriver slowly until the compressor and fans stop. With fans and compressor stopped for up to 30 minutes the defrost heater should come on. If doing this causes the defrost to take place simply replace the defrost timer. If not then please let me know and I will instruct you on how to change the=> 67001794 Defrost Heater Assembly and the 12001937 Defrost Thermostat Thanks Sea Breeze
Jun 28, 2013 | Refrigerators
Not cooling or freezing
Do you hear the compressor kick on, or try to kick on?If not, unplug the unit, remove the "overload relay" from the compressor and give it a shake. If it rattles, it is burnt out and needs to be replaced. Here is the new part.
If the "overload relay" is good, check to see if the "defrost timer" is stuck in the defrost mode. You can take a flat-head screwdriver and turn the timer til it clicks and it should start the compressor.
Keep me posted!
Oct 19, 2012 | Maytag MBB2256G Bottom Freezer...
My freezer is not cooling and leaking water what can i do?
It is possible that the defrost timer located inside the fresh food section in stuck in defrost. I want you to open the door to the fresh food section and above and inside the control panel where you adjust temperatures should be a small hole about the size of a pencil. Sometimes the hole is covered by a plastic plug. Remove the plug and turn the timer with a flat head screwdriver until the compressor starts. If the compressor starts this would indicate that the timer is defective and will need replaced. Let me know what you find. Thanks, Sea Breeze
Sep 26, 2009 | Maytag MTF2155GRW Top Freezer Refrigerator
Freezer not defrosting
you should find the defrost timer in the refrigerator section against the top of the refrigerator. Some models(not knowing what you have) have a small whole that has a slot for a flat screwdriver to go into and if you turn it, it will kick in the timer if it is stuck. Good luck
Sep 22, 2009 | Refrigerators
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Not cooling enough 60 degrees only, GE top freezer appliance. Door seal is fine,cleaned floor coils.
it may be the timer and a timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32
Aug 25, 2009 | Refrigerators
Where is defrost timer located on frigidaire refrigerator, model no ss180w-1.....17 years old
I couldn't pull up a line drawing for this model, but I recall that on these, (and other fridges of this age and era) had the defrost timer mounted under the front edge of the fridge, just behing the toe kick panel.
Some manufacturers mounted them at the rear behind the thin paperboard "cover", but I'd look for it at the front first.
In either location, it should be mounted behind a metal plate with a small hole in it that has a plastic or metal adjustment shaft that a flat bladed screwdriver slips into to manually advance the cycles.
Just remember to unplug the fridge before you disconnect the timer or attempt to replace it. Once you're done, you can advance the timer to initiate the defrost or cooling cycle, to gets things going.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Frigidaire Refrigerators
Freezer works. bottom won't get cold
You have a defrost problem locate the timer, advance timer until it clicks and compressor and the fan stop. Open freezer door and observe within 2 minutes you should see and or hear it defrosting. If so replace the timer . Set controls back to medium until back to normal. The timer should be inside top of fridge part, youll see a small hole as big as a pen, use a flat head screwdriver turning clockwise(it will only turn one way)) .
Mar 28, 2009 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
