Question about Dell OptiPlex GX620 PC Desktop
The cdrw/dvd drive has dissappeared after an update from microsoft. after trying to reinstall the drivers it still isnt showing up in my computer.could the upper and lower filters in the registry be corrupt? How do i fix this issue?
  • 540 Answers
Please follow the steps below to resolve the issue if you are not comfortable doing this then just take help from any friend or neighbour if this did not resolve the issue then replace the drive asap because it is a hardware issue.
1. Press Windows Key+R and type regedit in the text box and click OK
2. Click "File" in the menu.
3. Click "Export" from the drop-down menu.
4. Click the down arrow beside "Save In" and select Local Disk
(C.
5. Type Backup.reg in the File Name field.
6. Click Save.
=== Deleting UpperFilter and LowerFilter Registry Keys ===
1. Click Start and click Run.
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key
and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is
better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in
right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in
right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor and restart the computer.
CD/DVD drivers reinstall:
Press the Windows Key + R and type devmgmt.msc and press enter.
Device manager will open up.
Click the + sign beside DVD/CD Drives.
Right Click on the device listed under it and select Uninstall
Restart the PC and let the driver install automatically.
Check the issue once again.
Posted on Jul 30, 2010
Need a driver for SONY CDRW/DVD CRX835E
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Aug 07, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Need driver for Hitachi CDRW/DVD GCC4244
hope this helps
Jun 20, 2011 | Hitachi LG GCC4244N DVDROM CDRW Drive...
I have octo edge samsung dvd writer.. it reads dvd's fine no problem.. but it burns dvd or cd. it stops burning between 10% to 15%. and shows input/output error.. then the DVD gets wasted.. Is There a...
make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the drivers could be on it
your drivers may have been corrupted or you might have a virus run your antivrus program
hope this helps
Jun 18, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I connected my ide lg dvd rom using ide to sata adapter in my mother board as my mother board does not have any ide connection. so since ti gets detected during boot time but does not shows up or does not...
make sure that the cdrw/dvd is getting enough power test all leads that are attached to the cdrw/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 02, 2011 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
I still can not get the Laptop running Xp Pro sp3 to see the CDRW/dvd combo drive. I followed all of the previous instructions but when I get to the Place where I'm supposed to delete Upper Filters. There...
make sure that the cdrw-dvd rom is getting enough power test all leads that are attached to the cd-dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Apr 01, 2011 | Dell (8W007-A01) for Latitude, Inspiron...
MY CDRW DELL DIMENSION 5150 BURNER ISNT
im not sure what cdrw isnt doing so i will have to guess
you might have to physically unplug the leads for this cd-rw/dvd rom burner then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 20, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
My disk drive is stuck and will not read the disk. How do I fix this?
make sure that the cdrw/dvd combo is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd combo then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device ?
control panel admistrive tools,computer management,device manager scroll down cdrw/dvd drives?right click you can? you can update driver,roll back driver,or select properties general troubleshoot, select driver? click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 01, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
My CD DVD player won't work. TSST CORP CDRW DVD
This is the latest driver released by TSSTCorp for thier devices.
If this helped please vote kindly
Oct 09, 2009 | Computers & Internet
My DVD/CDRW only reads commercial dvds
My hl-dt-st cdrw/dvd gcc4244 ata device cannot write on DVD-rw imation cd why. How to resolve this problem
Dec 23, 2008 | Teac (DW224E/S) CD-RW/DVD-ROM (Combo)...
Dell OptiPlex GX620 PC Desktop Logo
94 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
