Question about MSI PM8M-V Motherboard
Mouse & keyboard not working
Suddenly My main-board not detected both mouse and keyboard. I remove CMOS battery but still has the problem. It can access in windows but mouse,keyboard not work. I cant access bios for this. USB keyboard also not work now. This is MSI PM8M-V motherboard.
How can I fix this problem. Please help.
    Brigadier General:
  • 10,406 Answers
You're "stuck" -- if the circuitry for the PS/2 keyboard and mouse is not working, and if it does not recognize a USB keyboard, the motherboard must be replaced (by an identical moetherboard, if you can find one, or a "newer/better" motherboard that takes the same CPU and RAM as your current motherboard).
Posted on Jul 30, 2010
Batteries ran down in the optical mouse. I put in new batteries and now I can't get the mouse to work. it's frozen
Remove the battery off and keep aside from within the mouse. Now disconnect the USB - optical detector to the PC. Shut down the PC . Replace battery once again and power the PC, then connect the USB to see if the mouse is detected.
If not remove off installed software of the optical device and reinsert once again so that it gets detected.
Nov 25, 2010 | Innovations kb985w RF Wireless Keyboard
I have a logitech Ex100 mouse/keyboard set & both have just suddenly stopped working. It tells you how to re-start the system by pressing 'connect' on the reciever & then the mosue &/or...
Do a Hard Reset method to clear the keyboard and mouse settings and reconnect it back to your computer:
• Remove the batteries from the keyboard
• Press the Connect button on the receiver for 10 seconds.
• Press the Connect button on the mouse.
(You might need a pencil tip or other small tip to press the connect button.)
• Insert the batteries back into the keyboard.
• Press the Connect button on the receiver.
• Press the Connect button on the keyboard.
Mar 02, 2010 | Logitech EX100 967499-0403 Keyboard
My computer won't start up and my mouse and keyboard are not working. Do I need to replace my CMOS Battery?
Yes turn off your computer and replace the Cmos battery. It seems that your keyboard and mouse is connected into the usb port of your computer, the usb function in the Cmos setup is disabled that's why your keyboard and mouse is not working. Upon checking the Cmos setup enabled the usb function and save the changes and restart the computer to take effect.
Feb 08, 2010 | Computers & Internet
Gateway one wirless keyboard has just resently quit working the only bottons that work are mute and valume my mouse stil works i am using the onscreen keyboard now tried new batteries what now
there is a bottom that rests the key board and the mouse and detect them from the usb blug try to press this bottom and detect the keyboard and the mouse
Sep 30, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
Light goes off & mouse stops working-have tried cleaning the light with alcohol on Q tip but doesn't help. it will stop working suddenly & start just as suddenly
If it has a wire to the back of the computer make sure its plugged in tight sometimes tahey come loose. if its wireless change batteries. If neither buy new mouse.
Sep 26, 2009 | Logitech Wheel Mouse Optical
I have an intel SE440BX-2 that does not recognize my mouse and keyboard. The scroll lock, num lock, and caps lock all flash repeatedly. The keyboard and mouse do not work at all. Tried 2 different hard...
hi im josh in cebu.friend if it wnt detect the probem is on your bios setup or on your motherboard parts like the cmos batt. you go to bios setup then go to pheriperals then choose enabled keyboard and mouse. or try to remove your cmos batt then afterr several seconds.install back firmly and tightenly. then reboot your pc.this will help you a lot good luck
Feb 23, 2009 | Intel Desktop Board SE440BX-2 Motherboard
Wireless mouse quit working
remoove the mouse cover and check the main led .most common fault is burnt out l e d.
nuwan
Sep 28, 2008 | Microsoft Wireless Notebook Optical Mouse...
Motherboard
I would start by process of elimination.
  1. Disconnect power cord
  2. open case
  3. remove button cell battery from motherboard
  4. press power on button to dissipate any stray voltage.
  5. re-install button cell battery.
  6. re-connect power cord
  7. power up pc.
If everything powers up ok and you get a CMOS checksum error, then enter bios set date,time etc. and go.
if the power on self test comes on and still no keyboard,mouse,video etc and no beeps. It may be your board or the processor.
Mar 27, 2008 | ASUS A8N-E Motherboard
Re: wireless mouse doesn't work
my wireless mouse has packed up the light is on ive tried new batteries what else can i try
May 25, 2007 | Impression Products Impression M1 Wireless...
Re: wireless mouse and keyboard; mouse not detected
I bought the same combo from a parts house. The guy told me the mouse didn't work but didn't know why. I had the same problem. When I inspected the mouse closely, I found that the connect button on the bottom of the mouse had stuck underneath the housing...basically in the "connect position". When I freed it, the mouse worked and still works just fine. Hope this helps
May 11, 2007 | Impression Products Impression M1 Wireless...
MSI PM8M-V Motherboard Logo
557 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
