Question about Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum
Does not put out steam; makes a clicking sound but does nothing.
    Problem Solver:
  • 5 Answers
Ru waiting 1 to 2 mins after turning switch to steam. because u must wait for it to create steam..just on start-up
Posted on Aug 15, 2010
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
I have got beldray. Steam mop not a vauuum I put water in switch it on red lights come on then go blue I will turn on steam and it will just not steam.
Lord Blake there sounds like there is a problem with the trigger or the seals for the steam pipe. Check it over completely and make sure it's assembled right.
Nov 02, 2014 | Vacuums
Easy steam express ll not steaming
The problem with the DD steam mop is not getting steam out but trying to get it to keep coming out. If U disassemble the plastic housing around the handle U will see a small part connected to 2 hoses, one going to the water reservoir the other going to the heating unit. This is the pump which provides water to the heating unit, and if this fails U won't get steam. U can try disassembling this and try to get the piston to move more freely. A loud clicking sound coming from this should indicate good movement and a feeble click click click may indicate restricted movement.
Hope this helps
Apr 28, 2012 | Dirt Devil CE7000 Easy Steamer Upright...
Water in shark floor cleaner is not hot
sounds like some kind of bad connection to the heater in it. how about the receptacle to which you plug into the wall,. is it making good contact?
Best regards
Ck
Dec 03, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No more steam coming out.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Apr 19, 2009 | Bissell 1867 steamMOP Stick Vacuum
Shark steam mop will not release water or steam.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
aa
Feb 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hoover steam cleaner I
E-mail me for the parts manual (firehead@rogers.com)then do the following.
Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Feb 01, 2009 | Hoover F5835900 Upright Steam Vacuum
Sharper Image SI570 Steam Wizard Handheld Wet/Dry Vacuum Logo
280 people viewed this question
Top Sharper Image Vacuums Experts
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
