Question about Minolta DI-2010F Copier
Minolta di-2010f is hung up, how do I reset the printer and pit it back to default setting
  • richwun Jul 30, 2010
    No paper jam, was doing a FTP setup on the Minolta and it said please wait for a long time. So I power down the printer and waited 5 min and power up the Minolta and it stuck on the first screen with the picture on the copiers.
    Jul 30, 2010 - Stuck in a state where it keep saying please wait and then a picture of the copier is on the screen and then it repeat the step again.
  • 4,323 Answers
Hi
Please turn off your Minolta for 10-15 mins and unplug it. After 15 min.s plug back the machine and reset the machine. To reset the machine check for a small hole to the right side of the display screen. Use a bent paper clip and reset the machine. After this machine will enter the reset mode & you'll be able to see a spot on top right corner of the screen. Press "3" to get into the reset mode. After this press trouble reset and the machine will reset. However, if the trouble reset isn't working then please try and open the right door & do a warm reset to enter the initial mode and then the Trouble reset button. Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Jul 30, 2010
Tengo problema con mi fotocopiadora dialta 2010f sale el codigo c0500
C 0500 fusing warm up main heater failure.Check that the fusing roller heater lamp comes ON when the power switch is set to ON,and correct or replace as neccesary.Check that the fusing roller sub heater lamps is OK,correct or replace.Check the instalation of the fusing roller thermistor and the fusing roller sub thermistor.Check the continuity of the heater lamp.To reset see image 5fd5fac2-0009-4536-8a7a-4e4da712d30d.jpg
Jul 11, 2014 | Minolta DI-2010F Copier
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
The problem is the print head that is were the LASER is located open close the front door to reset if it comes back replace the print head
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 01, 2014 | Minolta DI-2010F Copier
Di 450 earer coad c13f8
Print Head error. The print head is what houses the LASER for printing/copying. Open Close front door to reset. IF not replace the Print head. Worse case the image control board is bad. Also check all connections between the print head and the image control board.
Sep 14, 2013 | Minolta DI-2010F Copier
Minolta Di450 service code reset service code C1326
di450 . what is the solution of this code 1326?
Jun 09, 2011 | Minolta DI-2010F Copier
How do i get a report to print to let me know what faxes were sent and when
1) Set the original on the feed device or the glass
2) Press the (Fax/Scan) key.
3) Press (Fax Menu)
4) Press (Set 1), then press (TX Report)
5) Press ON
6) Press (ENTER) and put in the Fax number
7) After the fax went through, you will receive the confirmation
8) Once transmission is performed, it returnes to (Default), which means, when you send another fax, there will be no Transmission Report unless you go through the whole procedure again.
Jun 30, 2010 | Minolta DI-2010F Copier
Our copier is showing error code cof32
Sir,
Your image unit my have a problems has it been replaced recently, the starter my need replacing. What model is it BizHub, Di or EP? IF it is EP model then open and close front door to reset, if Bizhub or Di model turn on and off machine wait at least ten between on and off. If these dont work then starter/developer needs replacing and or ATDC sensor needs replacing
Feb 27, 2010 | Minolta DI-2010F Copier
How do I load staples into the Minolta Di 2010f copier?
Follow instruction on door. Push in on both sides of staple cart pull the top up install the new staple pack dont pull string on staple pack until its inside. (Staples on the floor:)) Don't throw away the plastic cart itself insure the arrows on the new staple pack match the direction on the old run or the staples will be upside down and not able to get out of the pack
Aug 17, 2009 | Minolta DI-2010F Copier
Di2010
A Print Controller can be installed.
Network print kit: NC-4 PCL Print Controller:
http://www.amatteroffax.com/ItemPage.asp?INVID=1047235&CT=1&CRY=%B4o%B8s%E7PQ%5D%60vT%B1%C8%F5%C9%87%BA%D2%B91%98%1FC
or a
Pi3505e Minolta PN:4513-612:
http://www.amatteroffax.com/itempagey_INVID_1047328_d_Minolta-Pi3505e-PostScript-3-+-PCL-Print-Controlle.htm
or you can install both if you wish.
I haven't found any data supporting the addition of a fax expansion kit. These models were before the FK-502 slide in expansions and I believe that's why the also sold the Di-2010f with the fax.
A network fax option, however, is available with the network scan kit.
Fax Kit:
Dec 22, 2007 | Minolta DI-2010F Copier
Minolta DI-2010F Copier Logo
142 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
