Question about Maytag MSD2454G Side by Side Refrigerator
My maytag msd2454gr refridge motor stopped running suddenly,I pulled away from wall and found a lot of dog hair in motor section so i assume it overheated..Can i fix myself? Or is it dead?
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezermy maytag msd2454gr refridge motor - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 31, 2010
Maytag refrigerator model #MFD2561HEW - Water dispenses from side wall. SUDDENLY STOPPED WORKING. Have replaced water filter. STILL NOT WORKING. Any suggestions?????
Hello, Thank You for using FixYa. I will be helping you today. Your water tank is frozen! Itson the back wall of the fresh food section if you look behind the drawers you will see it. Use a hair dryer and heat it untill you get water out of the dispenser. This is a common issue with this model.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Maytag Refrigerators
My Bissell BS3920F upright (similar to the 10N6F) has been working wonderfully for the past 3 years but suddenly seems to not pick up dog hair as well as it used to. It has been pulled apart by my husband...
Check to see if your brush is not worn down, they do wear with age - compare the length of the bristles with a new one. Replace the brush ir there is a significant difference in bristle lengths. Also check the flexible bend where the pick-up head joins onto the upright section for blockages and fluff.
Feb 24, 2011 | Bissell Vacuums
Maytag mzd2666geq refrigerator does not freeze - both freezer and refrigerator - it started yesterday afternoon. There is a lot of ****-frost on the freezer back wall. Evaporator motor is running (I...
REMOVE THAT FROST WITH A HAIR DRIER. THIS SHOULD MAKE IT WORK FOR UP TO 21 DAYS. THERE IS A 95 PERCENT CHANCE THE ADAPTIVE DEFROST CONTOL IN THE CEILING OF THE FRESH FOOD SECTION HAS FAILED. YOU CAN ORDER THE PART AT...
http://www.searspartsdirect.com/partsdirect/index.action
Apr 23, 2010 | Maytag MZD2766GES Side by Side...
Ice build-up water leak
sheck the back wall of the freezer where it sits in that trough, more often than not this complaint is the fault of a defrost drain. if you can try to remove the back panal on the freezer, if its a defrost issue there willl be a huge amount of ice behind that panal blocking the defrost drain.
after you chip what you can away, you'll find that a hair dryer and hot water are the best way to get that drain clear so it wont happen again
Oct 12, 2009 | Maytag MSD2454G Side by Side Refrigerator
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
Roomba Discovery 4120 barely moving
I don't have the same roomba that you have, but I had a lot of dog/cat hair stuck on the fan in the trash bin section. Once I removed that it started to work again. I used an air compressor to give it a really good blow out.
Here is a link that might help you out.
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=10960
Phil
Dec 27, 2008 | Roomba Robotic Floor Bagless Vacuum
Oven Fan Not Working Correctly
I am assuming this is a convection oven. There are only so many possibilities for this. 1) Bad fan motor 2) bad wiring from the board to the fan motor, 3) bad relay on the board. I recently ran a call on one of these and found a tech had replaced the oven temp. sensor had pulled it through oven cavity and in doing so pulled the wires loose from the fan motor, shorting out the board. Both had to be replaced.
Oct 30, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag MSD2454G Side by Side Refrigerator Logo
160 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
