Question about ASUS P5N-E SLI Motherboard
I would like to update my bios (to version 901) using the ez flash utility but am a little unsure how to name the file on the floppy disk my mother board is a p5n-e sli (its probably very simple but last time i buggerd my mother board some how)also it is reading as a bin file on the disk as well and not a rom file is that ok
  • 871 Answers
That would be ok. as long as youd remeber what you've save on the floppy and what specific BIOS update your going to install. but always be cautious, double and triple check if your doing and installing the correct thing...
Posted on Apr 24, 2008
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Tip
FLASHING BIOS - THE PROCEDURE
BIOS Update Procedure
All latest Motherboards today,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With
FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about
this.
Please read the following instructions in full before starting a Flash BIOS upgrade:
A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you
are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on
the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip from www.winzip.com or www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash
BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to
"Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE:
eg: a:\613J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or
Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete theprocedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to.
(This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot?
In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a
BIOS.If you have not used a bootable floppy, insure a clean boot either
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by
using the EDIT command.
Have you booted up under DOS?
Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important:
Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above
procedure (format a: /s and rebooting from a:\).Have you entered the full file name of the flash utility and the BIOS plus its extension?
Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS.
Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type
a:\615j900.bin, rather than 615j900.bin only.
on Dec 30, 2009 | Computers & Internet
Tip
BIOS Update Procedure...
All latest Motherboards today, 486/ pentium/ Pentium Pro etc., ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about this.
* With a non-formatted disk, type the following:
format a:/s
*If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you are flashing the New BIOS.
* Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
* Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the Winzip for windows shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD Roms found in computer magazines, have a shareware version of winzip on them.
* You should have extracted two files:
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file. This information is usually provided.
C. Upgrade the System BIOS,
Place the bootab le floppy disk containing the BIOS file and the flash utility in drive a, and reboot the system in MS-DOS, preferably version 6.22.
* At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
* From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" If you want to save (back up) your current BIOS (strong recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:\613J900.bin
* Select "Y" to "Are you sure to program?"
* Wait until it displays "Message: Power Off or Reset the system"
Once he BIOS has been succesfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not able to boo, and you will not be given another chance to flash. in this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
For AMI BIOS
Once the BIOS has been successfully leaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1. Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
In other words, did you the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
If you have not used a bootable floppy, insure a clean boot either by
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by using the EDIT command.
Booting in windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the abovr procedure (format a: /s and rebooting from a:\).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type a:\615j900.bin, rather tham 615j900.bin only.
on Dec 26, 2009 | Computers & Internet
How to update bios
hello f_franco32
to update the bios on this motherboard go to asus web site
www.asus.com
one on asus web site go to services ---> support -----> download
at the top left hand corner type in your motherboard model P5PE-VM, under that in select category selct Bios,
chhose your operating system from when the question pops up. (does not make any difference which windows version you choose. Bios in independent of your operating system.)
download the version of bios you want. the bios you download will have the utility with it but just in case it does not, download the bios utility as well.
format a floppy and make it bootable. copy the bios files to it. start the computer from the floppy and update your bios.
when you boot from the floppy at the command prompt you need to type in the utility name "Afudos" follows by the new bios name.
you can also do this using a bootable flash drive.
hope this was helpful.
please vote for me
Jan 02, 2011 | ASUS P5PE-VM Motherboard
I always have failure to boot and have beep sounds. Already installed asus update v6.10.02, still shows overclocking failed on start up and requests to configure BIOS. My system includes: inno3D-FX5500...
1-Does your computer show any sign of response after power button press?
2-Is your power cable properly connected and have main power switched on both your power supply unit and the wall plug?
3-Is the 20/24-pin ATX power connector has been connected between your motherboard and power supply?
4-Can The standby power LED (Green blue) light up continuously after the mains power is connected? (Note: Both flashing and off are no good here)
Fix 1
(1) Isolate The power going into your system ( i.e. connect your system to the wall plug directly, without sharing the power with any other devices via power extension cable.)
(2) Check if the power supply and power cable functions correctly, and have the input of your power supply set to the correct position (either 100/110V or 220/240V, depending on your country)
(3) Please try replacing your power supply.
Fix 2
1. No POST
1.1 Please clear CMOS to have a try (refer to motherboard manual for details)
1.2 If the problem still persists, please contact your retailer for a check
2. There is error message during POST: BIOS ROM checksum error. Detecting floppy drive A media... Insert system disk and press enter
2.1 If the support CD supplied with motherboard is available
2.1.1 Please restart system and put support CD into optical drive, then the system will recover BIOS automatically using CrashFree utility
2.2 If the support CD supplied with motherboard is not available
2.2.1 Prepare a formated floppy disk, then unzip the BIOS file downloaded from ASUS website into the floppy disk.
2.2.2 Please restart system and insert the floppy disk into floppy drive, then the system will recover BIOS automatically using CrashFree utility
2.3 If it is not helpful after the troubleshooting as the steps 2.1 or 2.2, please clear CMOS( referring to the manual introduction)
Fix 3
Please try the latest BIOS. I recommend you to use AFUDOS to update BIOS. You need to unzip it to get the ROM file.
You should use the command as follows:
AFUDOS /i[biosname]
or, afudos /i A:\BIOSNAME.rom(if the BIOS file is in the floppy disk)
You can store your BIOS into a floppy disk or a hard disk with FAT format. Then, you will be able to use AFUDOS to access the BIOS ROM file.
If it is not convenient for you to use DOS and AFUDOS, you can try to use EZ Flash. You can save the BIOS file into a flash disk then boot the system and enter BIOS, then you can update your BIOS by EZ Flash which is in the BIOS Tools page. Please load the default settings in BIOS after you have succeeded updating BIOS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | ASUS P5VDC-MX Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Upon reccomendation from a Microsoft tech and Acer, I have downloaded the current version of Bios update form my M5641, but have no istructions on how to perform the update. Please help
Ok, you must make a bootable DOS floppy diskette, or a bootable DOS CDrom if the machine has no floppy drive. You can download Windows executable DOS boot disk images here: http:bootdisk.com. I prefer DRDOS 7. There is usually a flashing utility and bios image file that you must copy to the floppy boot disk.
If your not very DOSSY, after the machine boots from the boot disk, you do a DIR, and find the name of the flashing utility. You enter that name at the command prompt: A:/. like this:
A:/flash_utility /h
That will give you help on how to use the utility.
But newer machines have smart bios that only need one file put on the boot disk, and everything is automatic.
Making a bootable CDrom requires special software that you must buy. Or you can use a Knoppix live CD, but you'll need one CD writer and one CDrom. It's ok if both are writers, or even if one is a DVD drive.
Bootdisk.com has bootable CDrom image files. But I only know how to get files inside the image file using Linux. There are programs for Windows that can edit a CD image file. Google 'edit .iso file. And don't pay money. There are good freeware programs. One is called daemontools.
You must copy the bios file(s) to the CD image, and burn the CD. Then boot with it, and do like I described above.
Apr 20, 2010 | Acer Aspire M5641 PC Desktop
How can i update bios
hiya
first goto the website of your board maker then download the updated bios, make a bootable floppy disk copy then exe file and the bios file it normally a .bin or .rom file when booted from the floppy run the flash utility with the exact name of the bios file so for instance it wud be
amiflash a123456.bin
hopw this helps
Rik
Feb 25, 2009 | Gigabyte Computers & Internet
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
All latest Motherboards today, 486/ Pentium / Pentium Pro etc.,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Please read the following instructions in full before starting a Flash BIOS upgrade: A. Create a Bootable Floppy (in DOS)
format a:/s
sys a:
This procedure will ensure a clean boot when you are flashing the new BIOS.
•Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip for Windows 95 shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
•From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:13J900.bin
•Wait until it displays "Message: Power Off or Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
For AMI BIOS Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips note: 1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
Have you done a clean boot? In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
Have you booted up under DOS? Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers. Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above procedure (format a: /s and rebooting from a:).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c: your will need to type a:15j900.bin, rather than 615j900.bin only.
Oct 19, 2008 | Computers & Internet
ASUS P5N-E SLI Motherboard Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
