Question about GE Spacemaker Washer and Dryer Electric Laundry Center
My washer will not agitate model #wsm2700hbwww
  • GE Master
  • 17,130 Answers
Check the voltage at the time of the agitation cycle and if there is no output from the program controller unit the fault is with the controller unit.
Since it works on other cycles the motor must work properly and the issue is with the controller,
Posted on Sep 30, 2011
Hi Christalee - Were you able to fix the issue. I have the same model and have the same problem...it wont agitate. Any inputs/suggestions would be great,,,,,
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Washer won't agitate
First, see the Sears parts site for washer model # 110.22952100 which I believe is your model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22952100+
Look at the section containing the agitator and you should see how the parts fit.
Also see the following for an illustrated description of replacing the "dogs"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore Washing Machines
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
Sep 26, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washer will not agitate
A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
Feb 11, 2007 | Kenmore 15864/15862 Top Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
259 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
