Question about Kodak ESP 5 Printer
My Kodak ESP5 is reporting that maintenance cannot be carried out because the printer may be busy, which it is not. The cyan ink is not getting through properly and I think I may need to buy another print head. Where can I get one and why do you think the maintenance function is blocked? Is there a print queue somewhere that I can access so as to delete whatever might be causing the printer to be busy? Many thanks, Alan G.
  • Kodak Master
  • 6,826 Answers
Http://www.kodak.com/global/en/service/products/ekn035324.jhtml?pq-path=12998
On this page it says to make sure you update your printer with the latest software and firmware updates.
I would also, unplug for 30 sec. and replug the printer in to power to reset it.
I would get a cyan ink cartridge from Walmart or another retailer.
Usually, there is a print queue with an icon on the bottom bar of Windows when there are pending documents.
Good luck on this repair.
Posted on Jul 30, 2010
Black ink will not print
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jun 18, 2012 | Kodak ESP5 AllInOne InkJet Printer
How to remove the ink cartilidge
How do I install a new printhead in my all-in-one printer? To replace the printhead in your all-in-one printer:
  1. Make sure the printer is on.
  2. Lift the printer access door and wait for the carriage to move to the access position.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers:
    • On the printer control panel, press Home.
    • Select Maintenance, then press OK.
    • Select Install Ink Cartridges, then press OK.
      If "Install Ink Cartridges" is not an available selection, upgrade the firmware.
  3. Remove any paper that may be loaded in the printer.
  4. Remove the black and color ink cartridges and set them aside.
  5. Remove the existing printhead:
    • For ESP Series Printers, unlatch the printhead by lifting the latch in the center of the carriage.
    • For 5000 Series Printers, unlatch the printhead by pressing the button in the upper-left corner of the carriage.
  6. Lift the printhead out of the carriage.
  7. Remove the new printhead from its bag.
    CAUTION: Do not touch the copper contacts on the printhead, as this may damage it.
  8. Remove the plastic protective shields.
  9. Place the new printhead into the carriage.
  10. Push firmly against the target label of the printhead until you hear a loud snap.
  11. Insert the color ink cartridge into the printhead and press down until you hear it click into place.
  12. Insert the black ink cartridge into the printhead and press down until you hear it click into place.
  13. Close the printer access door.
    The printer detects the new printhead. Follow the instructions on the LCD to calibrate your printer.
    NOTE: ESP 3 all-in-one printers do not require calibration.
IMPORTANT: Be sure to use KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. You can purchase KODAK Ink Cartridges from the KODAK Store.
Feb 09, 2011 | Kodak ESP5 AllInOne InkJet Printer
Our kodak ESP5 wont print properly. We have installed new ink (a number of times now) but the ink is still very faded when printed. fed up of having to buy ink and still wont print out dark.
Sounds like print head needs replacing, try the troubleshooting guide on Kodak website to confirm, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
Dec 30, 2010 | Kodak ESP 5 Printer
Istalled new ink cartidges in a Kodak ESP5 and color is faded and Black and white in not even there ??
issue is with printhead.
Try re-installing the ink cartridge....clean printhead from Menu > Maintenance > Clean printhead.
Else, visit www.kodak.com/go/itg and follow the steps to order a free printhead for you.
Or
call 18004216699 and get a printhead free of charge
Jan 24, 2010 | Kodak ESP 5 Printer
Kodak ESP5 new cartridge error msg: cartridge needs replaced
Try using a new pack of ink cartridges.
If still face the same issue, conntact Kodak support.
They will send you ink cartridges, if still the same issue persists the printer will be replaced.
Dec 20, 2009 | Kodak ESP 5 Printer
We are having trouble with our kodak ESP5 printer it wont print using black we have changed both cartridges and ran it through the cleaning it also only sees that the black is 1/2 full and it's a new black...
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 13, 2009 | Kodak ESP 5 Printer
My Kodak esp5 says my print head is not connected. I am using Kodak ink. Can you help please
Try installing the printhead 2-3 times. If still get the same error message. call Kodak tech support, printhead will be replaced free of charge
Dec 02, 2009 | Kodak ESP 5 Printer
My printer will not print out blue, I have put in two new cart,but think it must be printhead ( kodak esp5)
Click on menu on the printer,scroll down and choose clean printhead or go to maintenance and then click on clean printhead .After that try to print. If issue persists,call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad..
Oct 20, 2009 | Kodak ESP 5 Printer
I Filled Kodak ESP5 Ink Cartridge, but error remains
Try to reseat the cartridge 2-3 times. probably the carrtidge is defective. call kodak @ 1800 421 6699 and they will replace the cartridge for you free of cost.
Apr 14, 2009 | Kodak ESP 5 Printer
Black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Mar 29, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
289 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
