Question about Danby Heating & Cooling
I have cleaned the unit entirely but it's still not cooling the area I have it in what else could be wrong with it?
  • 6,826 Answers
The freon could be low on it causing the coils not to get cold enough.
What model is it?
Posted on Jul 30, 2010
  • cobear Aug 05, 2010
    How could I check the freeon in my Danby DPAC120068 if that proves not to be the problem is any other things you may suggest I try?
  • Duane Wong
    Duane Wong Aug 05, 2010
    http://www.danby.ca/cms/uploads/products...
    The above is the manual for the unit. I read over it and it seems like many other units
    made by Danby.
    Is the water full light on? This will occur when the internal reservoir is full. It's recommended to use an external tank to extend times that the unit can work without having to empty the water out.
    You can feel if the coils are getting cold with the back of your hand close to but not touching the coils (so if it's really cold you don't want to get stuck to the coil). They should be like 34 to 45 deg. F or so when operating correctly.
    Make sure that the mode is on 'cool' and not 'fan' or 'dehumidify.'
    One might press the 'reset' button on the remote to reset everything back to factory specs, including the 75 deg. F temperature setting.
    Adjust this setting so that it's cooler than that for your comfort.
    If all else fails, one might want to call the 1-800-26-DANBY phone # for assistance.
    There is an 18 month limited warranty on the unit for manufacturer's defects assuming it was not treated badly in any way (i.e. electrical shutoff, surges, or mishandling of the product).
    I noticed that it's still a current model.
    I wish you luck in getting the Danby Portable Air Conditioner working properly.
When i turn On my PC this thing shows in the monitor. <300 XT BIOS P/N 113-A33437-102
Open the case, loosen the 2 screws holding the black plastic casingon the cooling tower over the CPU. Carefully remove, or tilt back to reveal cooling tower radiator and coil.
If there is a layer of dust built up (like there was on mine); carefully vacuum clean the radiator, cooling tower unit, fan and all other surrounding areas. Clean any residue from tower-to-CPU contact area.
Vacuum entire PC inside and out. Remove, reseat, vacuum video card. Reseat storage drive cables reseat the memory sticks, close it up and plug it back in start computer.
Jun 05, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
FAC122P1A I have a small 2 bedroom apt. maybe 700sq. ft. with bedroom doors closed the unit isnt cooling apt. as well as it did even a couple of weeks ago. The unit is blowing cool air but not enough to...
This unit probably need to be cleaned. Im in St. louis MO and its above 100 degrees with a heat index of 116 if your area is experiencing this kind of heat as we are there may be nothing wrong at all A/C units are designed up to 95 degrees when it get hotter than that the units never shut off till night fall.
Jul 21, 2011 | Carrier YC273D Air Conditioner Window/Wall
Jusrt bought a mobil home with an Interherm unit. I live in Louisiana. When the air was hooked up is didn't cool very well. The fan motor outside had to be replaced. I was told it was the wrong...
There are a few things you can try.Close the vents half way in rooms your not using often too force more air to where you want it.
Inside coil and filter may be clogged or dirty.Change filter and clean coil with a degreaser spray,simple green works well mixed with water.
Thermostat location? is it in a common area like the living room.If not it should be there.
May 10, 2011 | Intertherm P3RA-024K Air Conditioner
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
The upper area were is not frezzing is not cooling
heatman101
sgasgaiyl
Jul 15, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer ice maker stopped working. then entire unit stopped cooling, fan is not working. Light is on inside the unit.
heatman101
ghjd
May 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Air Conditoner not cooling entire room
I would guess by the question you posted that at one point this air conditioner DID cool the entire room. If that is in fact the case then chances are you have either 1. A dirty air filter, which can be found underneath the front grill of the unit, or 2. A dirty condenser coil, the coil found on the back of the unit, that is outdoors while the air conditioner is in the window. If this coil gets clogged up, then the proper heat transfer will not take place, and you will not get proper cooling. Hope this helps.
May 07, 2010 | GE AGF05LA Air Conditioner
Not cooling in refrig area & low cooling in Freezer area;after running couple of days not cooling
heatman101
fdsjd
Sep 24, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Heating & Cooling Logo
23 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
