Question about LG LS-L1210CL Mini Split Air Conditioner
Condenser gets blocked due to ice formation despite cleaning
At low temperature condenser gets chocked with ice. If it is shutdown for a while then it again cools very well for few minutes. But not more than 15 minutes it is again blocked. Is there any solution to this problem ?
  • LG Master
  • 43,501 Answers
Sounds like you have a leak in the system and the unit is low on charge...
Here is a tip for other things you can check first....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 30, 2010
Condensation on frigidaire dehumidifier turn to ice
Good Morning Friend,
I understand that the condensation is turning to ice on your Frigidaire dehumidifier, model# LAD704TDL. This can be a possible cause of your dehumidifier being turned on recently. This is normal, due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another possibility is the room temperature is too low. All dehumidifiers will operate satisfactorily at temperatures greater than 41 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Dehumidifier LAD704TDL
I have a GE GSS22 model side by side that is not properly cooling or freezing. I've removed the back panel in the freezer to expose the compressor coils and they are not frozen. The motor and fan in the...
Pull the refrigerator out and remove the back bottom panel. Also remove the kick plate in the front. The condenser coils are probably dirty (if you've never cleaned them, they are probably LAYERED with debris). Get everything cleaned out under there, be sure the condenser fan (in the back of the refrigerator) is working and see if that doesn't help. Dirty condenser coils can exhibit the exact same symptoms as more serious problems like a failing compressor.
Mar 07, 2014 | General Electric GSS22JET Side by Side...
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Temperature is to worm in Freezer
Could be any one of these problems
\ evaporator fan not working
\ ice blocking air flow
\ thermostat worn out
\ low refrigerant charge
\ blocked or dirty condenser
\ poor air flow over the condenser
\ compressor valves burnt
Mar 24, 2011 | Gladiator 19 cu. ft. Chillerator Garage...
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
RFA 70 fridge freezer high temp light is on
Check condenser. If dusty, clean it. Due to short of gas/ chock in the system will make high temp. If chock you won't whistling sound in freezer, If short of gas, the condenser coil will not be warm. Call repairman to rectify the fault. Thanks.
Feb 07, 2011 | Refrigerators
How to determine evaporator icing problem of air conditioning units
Due to :
1.. Evaparator coil dust blocked. 2. Air filter blocked. 3. Less rpm of fan motor. 4. Short of gas. 5.Filter drier chocked 6. Compressor less pumping.
To rectify:
1 & 2.Clean air filter and evaporator. 3. Replace fan capacitor. 4.Check for gas leak and recharge. 5. Replace new filter drier, vacumize and gas charge.
Dec 16, 2010 | Heating & Cooling
I have a Goodman condensing unit that freezes up occasionally during low ambient weather (20 F). Model # ssz160361ac with matching new air handler. I have adjusted the defrost time from 90 to 30min. This...
It is not freezing up because of the temperature, but because of ice being formed in inside. Either by a blocked condensation duct, or snow due to previous storm.
Jan 31, 2010 | Goodman Heating & Cooling
Frigidaire side by side model# PLHS269ZCBO
How cold is the freezer? Check the condenser coils for cleanliness and clean if necessary. Condenser may be located in the back behind a fiber panel. Ice maker is dependent on temperature and if the freezer is not reaching a low enough temperature it will affect your ice production.
May 06, 2008 | Freezers
LG LS-L1210CL Mini Split Air Conditioner Logo
106 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
