Question about Craftsman Garden
On a 10 inch power compound miter saw, I need to replace the blade. Does the blade bolt have left handed threads? Thanks
  • Anonymous Mar 24, 2014
    I cannot get the hex nut to turn to get the blade off.
    President:
  • 2,220 Answers
Place a finger nail in the thread near the end ot the shaft. If when rotated CW it comes off the shaft it is a left hand thread. My 10" Craftsman radial saw has a left hand thread on the blade shaft.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 30, 2010
Blade keeps coming loose
Check to make sure the blade washers are installed correctly and the right order The thread is left handed on the bolt and should tend to tighten from the toqure of the motor spining If this dosn't you could try a drop of white lock tight on the threads of the bolt but don't use red locktight its to strong
Jan 30, 2011 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I'm having problems replacing the blade on my Hitachi C10FC2 miter saw
it should have lock button some wear on it push it in. this will keep the blade from move. so you and take the blot off
Jan 18, 2011 | Hitachi C10FCE2 10" Compound Miter Saw
Lost my manual. Need to know how best to switch blade
There is t shaped scocket type wrench that came wuth the saw that pushes into the saw next to the rear handle it fits the bolt that holds the blade on.There is l shaped metal locking buttom on the front of the motor houseing. The bolt has left handed thread so it loosens in the oppisite deriction as a normal bolt clockwise. push the L shaped button in to lock the blade loosen the bolt remove the washer and blade install new blade in reverise order
Dec 22, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
How do I replace a blade on a Delta 36-585 miter saw
There should be a wench on the mecnine that fits the bolt. the bolt turns in the oppiste derection as a normal bolt its called left handed thread this keeps it from coming lose during use. There is a buttom you need to press to lock the shaft then lossen to bolt lift the blade gaurd replace the blade note the washers that go up against the blade and make sure you install then in the same order as they were removed
Dec 17, 2010 | Delta SM100M 13 Amp 10" Compound Miter Saw
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
I have 1 10 In compound miter hexbolt will not loosen and lock will not hold. Is it possible that the bolt is a left thread?
most mitre saw bolts that hold blade are left hand thread. If you overtightened you might have to use extra force to loosen, on occasion I have had to use an impact wrench to loosen.
Jul 13, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Need to replace blade on Superior 10'' sliding compound miter saw
There is a bolt in the middle of the blade you must loosen and remove it and the blade will come off. THE BOLT IS LEFT HAND THREAD so be careful not to turn it the wrong way or it will break. Superior is out of business so you probabley will not be able to get a new one.
Hope this helps
Mar 05, 2009 | Saws
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
