Question about Citizen Eco-Drive Calibre 8700 Wrist Watch
Citizen calibre 8700 will not reset (hands do not move) - second hand moves in 2 sec increments
SOURCE: the second hand is not moving
Are you sure the big second hand is not used for the chronograph? I once had a watch that did exactly that. There was a small second hand in the lower left which was the normal secondhand, while the big second hand was used only for the chronograph. It annoyed the cr*p out of me, so I always had the chronograph running, just so the second hand would move.
Posted on May 24, 2008
I have the same problem with my watch. The second hand
tends to stop even if it's not dim. Leave the watch outside
in bright sun for several hours. I've found that this will charge the watch so that afterwards,
the second hand will work even inside (well, not all the time,
but if it's fairly bright).
Posted on Jul 03, 2008
  • 2976 Answers
SOURCE: Casio Lineage Waveceptor 4717 minute hand off by 20 seconds
You would have to remove the movement from the case, remove the hand and reinstall it, to where you want it.
Posted on Aug 06, 2009
SOURCE: My Citizen Eco-Drive second hand is broken
I think Its required Recharging capacitor
Put your watch under lamp light for 12 hours I hope that will solve the issue if not then capacitor need to be replace or watch need cleaning
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Oct 01, 2009
  • 93 Answers
SOURCE: I own a Citizen Eco Drive Calibre 8700 Blue dial
If your watch was not stored where it could have light shining on it the LI battery would drain completely. There is a possible solution although it does not work all the time. It depends on how badly the battery has been allowed to drain.
Setup a lamp that will shine on a counter 24 hours a day and set your watch there. It helps if the lamp is about 1.5 - 2 feet above the watch. A 60 watt incand. lamp will work fine.
Leave your watch under this lamp for 3 - 4 days 24 hours a day. This will supply the solar cells with enough energy to recharge the battery and get it working again. If after this time it is still not working then the battery is just not going to accept a charge again or there is something else wrong that a watchmaker is going to have to fix for you.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Nov 03, 2009
Which way is clockwise as you hold it in your hand and one time that i set it it went around by it self another times i had to wind manually
Clockwise is the way you read the numbers 12,1,2,3,4,5, etc. the way the hands move. If there s a digital display that is supposed to match the hands, Set it first then find the menu setting for hands
Nov 23, 2015 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Hour and minute hand not moving
its quit easy to open the watch and try repair it yourself,and it lets you see what parts connect to what part and if they moving or not and leads you to some solution,or you could take it to a repair shop
Jan 09, 2014 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
Aug 01, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
I need to know how to set my 8700 calibre watch
Hi,here is a solution to help you out:
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
However,you still have every reason to own the manual of your wrist watch for future references,so follow the link below to download the manual of your wrist watch;
http://www.citizenwatch.com/COA/English/settings.asp
There are so many aplications use of the manual will be manditory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Thanks and take care
Jun 20, 2010 | Citizen 8700 BL8000-54L Wrist Watch
How to change the date and week?
Hope this helps as it took me using the correct movement number on the url in the previous post (for Calibre 8700 the movement number is "E870").
Mar 22, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
Feb 01, 2010 | Citizen Eco-Drive Calibre 5700 AT1070-54L...
I own a Citizen Eco Drive Calibre 8700 Blue dial Romen letters. I have not used it for very long time (6 months). Now when exposed to light only the second hand works but the minute hand and hour hand do...
Hope this helps.
Ken
Nov 02, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 | Watches
Got the same problem guys. i have one of the new electronic diving eco drives.
First time i managed to get it going again, by forcing all the hands to the top for diving mode, then back to normal, this action ´nudged´the minute hand back into motion, but a little later it stuck again at the same spot.
I guess mines going back to the factory, and i´m gonna b watchless for a few weeks :(
Jan 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
337 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
