Question about Britannia SIE9TLS Electric Kitchen Range
Hello both ovens and the ignition are not working no power to the clock the gas is working if i use a lighter there is no fuse because there is no plug its wired i think to the mains can you help
Was adjusting the temperature dial when oven shut down clock is off as well and electric gas lighters for elements not working, what would cause this - I have checked the power supply box and it is fine
clock must be set to correct time or it will hinder proper operation of oven
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 18, 2015 | Ovens
I have lost all power to the ovens and clock..but the gas igniter still works
No make or model given so answer is general in nature-
Burner igniters are not normally controlled by the main electronics board that supplies signals to the clock and oven controls.
This may be caused by a blown fuse on that board, a failure of the board itself or the power supply that provides operating voltage.
Feb 03, 2015 | Ovens
Whirlpool gas range
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Jul 26, 2014 | Whirlpool Ovens
STOVES 900DFa not working
Probably a silly Q but does the clock come on?
My \\\\\\\\stoves needs the clock setting before the oven and ignition will work
Feb 14, 2010 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
The clock(computer?)broke so I replaced that part it seems to work. I then tried the oven it will not light. The ignition glows red but does not light the gas. I can smell gas. I tried lighting the oven...
Just because an igniter glows, does not necessarily mean it is good. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
It sounds like you may have had a couple of problems. The gas smell concerns me though. If an igniter is weak, you shouldn't get any gas flow in the oven. This is a designed safety feature that prevents free flowing gas from filling up the oven cavity without ignition. I would recommend checking your igniter for the proper current and/or replace. The link I provided, lists the steps required. If you have any questions, please let me know. I hope this helps you.
Jun 25, 2009 | Frigidaire GLGF377 Gas Kitchen Range
Fiigidaire gas oven trips power when I turn oven on
disconnect the wires going to the oven ignitor,turn the unit on see if its trips.if so the ignitor is shorted if not then disconnect the wires that go to the coil of the gas valve and do the same.i think either one of these is your problem.also if theres a fan in the oven do the same.
Jan 05, 2008 | Frigidaire FGB24S5A Gas Single Oven
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Britannia SIE9TLS Electric Kitchen Range Logo
24 people viewed this question
Top Britannia Kitchen Ranges Experts
James Gettemy
Bill Boyd
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
