Question about Acer Aspire One PC Notebook
When I turn on my notebook, it keeps going back to the startup menu
  • lilangels120 Jul 30, 2010
    Hi the solution the last person gave me did not work. I have tried everything to get my computer to boot up but it keeps going back to the start menu
    Top Expert:
  • Acer Master
  • 77,499 Answers
What operating system do u have? have you tried doing a system restore to a time/date when the problem was not there?.
Posted on Jul 30, 2010
  • 3 more comments
    I have a notebook aspire one ZG5. I can't get to the system restore menu because my computer keeps going back to the window that has all the safe mode start maually ect
  • yadayada
    yadayada Jul 30, 2010
    I asked what operating system u have, XP, what?
  • yadayada
    based on what I have seen with problems like this the easiest thing to do here is reload the operating system from the recovery disks
  • lilangels120 Jul 31, 2010
    I have xp and I dont have any reboot disk
  • yadayada
    yadayada Jul 31, 2010
    then u need to order a set from Aspire, this is not a reboot disk it is the whole operating system, they run around $12, call or email support for ordering instructions at eh Aspire support web site
  • 4,281 Answers
First when you power up the computer press F1 or F2 or del or ALT+F2 key for enter in bios. Then go to boot menu and set first boot device as your harddrive. Then save settings and exit. Then if you get every time safe mode and other option then enter in safe mode then if you are able to enter in safe mode then go to start menu->run or press windows key + R key so you can see run type in chkdsk /r" without "' then press ok then restart computer then it will fix and recover errors on harddrive but if you are not able to enter in safe mode too then boot computer with windows disk then follow the procedure and choose "repair windows " option then it will work again. Let me know if you need further assistance. Thanks for using FixYa.
Keeps restarting about every 10 minutes.
Could be a possible Virus/Spyware related issue or startup items are causing this issue or could be issue with graphics/video driver etc.....
Unplug all external peripherals/devices if any.
When you say you restored it do you mean System Restore to an earlier time or ?
Feb 22, 2014 | Acer Aspire 5742Z-4200 Notebook
My screen keeps flashing" diagnosing your PC" why
There is a problem with your windows 8 PC's installation, which has stopped it from booting correctly; hence why it starts in 'startup repair', and tries to diagnose your PC. Hold the F8 key while booting your computer to go into the startup menu for Windows; click Advanced startup options; and select Restore my PC; which will reinstall windows.
This may or may not work for your machine, you may have to hold F2, F10, or the Escape key to go into the UEFI setup and go into startup options from there.
Dec 20, 2013 | Gateway Computers & Internet
Reset password
PLENTY OF FREE TOOLS FOR YOU TO DOWNLOAD GET THE SIMPLE TASKS LIKE BOOT MENU #TURN OFF THE PCOR THE LAPPI AND F2 AT THE STARTUP AND KEEP PRESSING TILL YOU SEE THE SCREEN IN BLACK MODE AND FROM THERE SEE THE %TEMP% CLEAR IT OFF THEN GO TO ADMINISTRATOR NAME AND LEAVE IT BLANK
Sep 28, 2013 | Acer Aspire 7720-6155 Notebook PC
My camera is not working.it says in use by another application. I dont know which application is using it actually none of those apps are turned on.How can i fix it?
It is possible your Startup files contains Skype, VID, PhotoBooth, or some other program that hijacks your webcam. Even if you don't have those programs running they may keep you from using a different application. You will have to manually go through any type of program that could use your webcam and turn off the camera, and/or remove those programs from your Startup menu.
May 12, 2010 | Logitech Webcam
My laptop as randomly started shutting down on its
Put you Vista DVD in the drive & boot off of DVD, and when you see the menu select Startup repair... leave it go on through it's process and reboot when told , this should repair your startup issue, otherwise get back to me.
Feb 18, 2010 | Compaq CQ60-215DX Notebook
I cant seem to log on
try starting in safe mode. hold down f8 when you turn on your computer until you get a menu with the option to boot in safe mode. once you successfully log on in safe mode, restart your computer and the problem should be cleared. if not, we can explore further options.
Aug 14, 2009 | HP Pavilion dv9000z Notebook
Erecovery acer 5315
You can "try" to stop the process from starting by unchecking the appropriate box under boot menu.
go to RUN, type MSCONFIG, check the startup tab.
Hope this helps.
Jun 15, 2009 | Acer Aspire 5315 Notebook
Mac book will not turn on.
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed: 1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
May 29, 2009 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
I have to turn it on twice! It turns on normally and just when its about to load windows the screen goes black, then I have to turn it off and on again for it to load windows.
You can choose go to advanced startup menu by using F8 during startup and choose "Last Know Good Configuration"
about DVD playback; right click on your DVD drive (Usually D drive) on properties go to Recording tab and check the box highlighted below.
Good Luck
Jan 21, 2008 | Dell Latitude D600 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
