Question about Euro-Pro Shark 9110 Sewing Machine
The thread in the bobin isn't comming up too the needle. I have removed the face plate and cleaned it out, but it still isn't working. What could this be?
  • Euro-Pro Master
  • 7,365 Answers
Make sure the needle is facing in the correct direction
Put the bobbin in the bobbin case leaving a
2 to 3 tail.
Thread the top of the machine correctly, leaving a 3 to 4 inch
tail after threading the needle.
Hang on to the end of the upper thread and use the handwheel to drop the needle.
continue to turn the handwheel to raise the needle. Pull on the end of the needle thread and a loop of bobbin thread should come up.
make sure there is no lint or loose thread in the bobbin area
Posted on Jul 30, 2010
Pfaff creative 2134.....needle is hitting the bobbin casing
There is two possible solutions. either the machine has been knocked out of time by a thread jam or the needle rod has been bent. Good Luck!
Apr 19, 2011 | PfaFF Sewing Machines
Is there any other thing I can do to stop the thread from the upper looper from breaking after about 30cms of sewing. there is no sign of it being about to break. I have changed thread, needles and...
it could be due to one or more of the following
  • Threading is not correct.
check that bobin is not snagging thread,
remove bobin and remove any dust and fluff from bobin area
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Correctly thread machine.
  • Replace needle with correct size.
  • Properly insert needle.
  • Start machine at a medium speed.
  • Check threading order.
I hope this was helpful
Jan 05, 2011 | Husqvarna Huskylock Computerized 910
The top thread is looping every 30 or 40 stitches on my Juki DDL 8700. I put in a fresh needle, cleaned thoroughly, fresh throat plate and re-threaded. Any ideas? Thank you!
hi there
please check bobin case spring maybe need t adjust or rplace.
please check if you are wind bobin by correct way not too much titght or not too much loose. thread insaid bobin must be littel soft.
the last reason maybe the tip of stoper for hook id damaged and need to rplace.
best regards
ashraf abozid
aabozid@hotmail.com
Dec 01, 2010 | Juki DDL-8700
Bottom thread not picking up for 4500 series,,,tried new needle.new bobin,new thread,,pliz help
The most common reason the bottom thread won't pick up is because the needle is inserted wrong. Check that the needle is inserted with the flat side of the needle shank is facing away from you.
Robbie
Aug 09, 2010 | Toyota SE-06 Mechanical Sewing Machine
Unable to get the bobin thread to the top of
Hi. The most likely reason for this is that the needle is not inserted correctly. There is a flat side to the needle shank that has to be inserted facing a particular way--to the right as you're facing the machine, or to the left, or to the rear, facing away from you. Most modern machines need the flat side of the needle facing to the rear, so try that first. Also make sure the needle isn't bent or dull.
Hope this helps!
Robbie
Apr 08, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
The bobbine thread is not catching and I'm trying to fix it and I am not sure were to start.
start by removing the bobbin, and reinstalling, make sure the thread runs through the bobin tension plate, the little plate that puts pressure on bobbin thread to keep it tight, also look at thread and needle, if thread insn't thread through the needle, it won't catch, feelfree to call me if you need better help, devin 239-895-4845, Quality Auto Trim Inc 239-849-0015
Mar 12, 2010 | Sewing Machines
Thread is knotting up under the feed dog plate getting error LO.I tried removing the plateand cleaning and replaced bobbinholder and it is still jamming. is there supposed to be any play in the bobin...
It should move a little so the thread has clearence. If the thread is bunching underneath, it usually means the thread's not in the take-up lever or top tension is too loose. If you're needle has hit the bobbin case and created needle marks, the thread can get caught... in which you'd need to replaced the bobbin case.
Feb 23, 2010 | Janome 8080 Computerized Sewing Machine
I am having a problem with my Shark Intell-Sew that I've had a few times before but I've always been able to resolve it, and this time I can't. The machine jams, and the book says it's usually because the...
Many machines today have a horizontal thread delivery for the needle thread. Be sure and place the thread spool with its tiny notch on one end (the notch is used to secure the loose thread end when not in use) facing toward the far right side of the spool holder and not facing toward the left side where the thread will be guided off the thread spool into the vertical tension discs and toward the needle. Some times this tiny notch will catch the thread causing undue thread tension on the needle thread. Placing the thread spool facing toward the right seems to help the thread guide off the spool without catching in the tiny notch.
Also hold onto the needle thread and the bobbin thread, giving slight hand tension to both, for the first few stitches you make in your fabric. With the first uptake of the needle, the needle’s thread tail and bobbin tail are drawn down somewhat loosely into the bobbin case and can become tangled and jam if not held onto briefly. Be sure the bobbin thread comes out of the needle plate in the area it is intended to. After winding a new bobbin, it may help to put the bobbin in its bobbin case and just raise the machine needle by hand just enough to allow the needle to bring up the bobbin thread to the top. Give the bobbin thread and needle thread held together a slight tug so that they both lay out behind of or to the side of the needle. If you have left off the needle throat plate for last (for those machines that allow the throat plate to be removed) when placing the throat plate back on the machine, be careful to guide the bobbin thread through the hole or space in the needle throat plate so the bobbin thread lies on top the plate.
Using the right machine needle for the fabric helps too. Generally, ball-point needles work great for knits and sharp-pointed needles for woven fabrics. Using the smallest size needle that makes the best stitch for the type of fabric seems to work well for most fabrics to produce clean even stitches.
Using the best quality thread helps. The bargain-priced threads found piled in sale bins at the fabric store work great for hand sewing but not for machine sewing. Lesser quality thread make lots of fuzz as it passes through the needle and can jam the machine. Many sewing machine repair folks hate the thought of us using a can of compressed air to blow out fuzz from the tiny spaces of the machine, particularly the newest digital electronic machines, but a spritz or two of compressed air in the vertical thread slots that hold the tension discs and in the bobbin case itself, usually can dislodge bits of fuzz from these spaces. Although compressed air is not recommended for a new machine the thought is offered for you to consider for older, mechanical machines.
Sep 12, 2009 | Euro-Pro Shark 60 - 384
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Jan 04, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 3962 Thread Catching Under face plate (catching on position finger)
I had a problem with the thread balling up under the face plate, too.
I have a Kenmore 385 16528000. I don't know if with other brands that this will pertain to them, but this was my solution:
I had the needle in the wrong way! The top part of the needle that is inserted into the machine needs to go in with the FLAT SIDE AWAY from you. So I hope that helps somebody!!
Elayna
Jul 13, 2008 | Sewing Machines
Euro-Pro Shark 9110 Sewing Machine Logo
251 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
