Question about Samsung Dryers
Samsung dryer Mod DV328AEW/XAA electric 220v dryer tumbles but does not heat.I've checked and power is 220v (working) There appears to be no burnt wiring, inside. and heating coils appear to be intact.
  • 1 more comment
  • Anonymous Mar 17, 2014
    I replaced a the heating coil and in the process did not pay attention and the coil was hitting and ground out in which in burnt the coil in two. Fix that problem but now the dyer will count all the way down to one and not shut off. What have i done?
  • Anonymous Mar 20, 2014
    need installation
    need wiring diagram on samsung dv328aew/xaa
  • 6,784 Answers
HI. Ok, this unit is equipped with four thermostats that monitor the cycling information and the heater box for optimal operations. All of the thermostats should be tested for proper functions. I suspect that the culprit will be the thermostats mounted on the heater box, but test all to isolate.
Here are all the thermostats that are to be tested, below:
1. Thermal fuse - This will be mounted on the side of the heater box(chamber). Test properly to confirm its functions.
2. Cycling Thermostat - This will be mounted on the blower housing.
3. Cycling thermostat(2) - mounted on the blower housing
4. Hi-limit thermostat - Mounted next to the thermal fuse on the heater chamber/box.
Concerning the element:
You cant always tell by looking. This device must be tested to confirm that it is indeed working as designed. It should show some signs of continuity if it is indeed functioning.
Proper testing technique for most thermostats and fuses:
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Posted on Jul 30, 2010
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to www.repairclinic.com and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Samsung dryer dv328aew/xaa won't turn off
It seems to me that you have a defective relay in the main control board.
Oct 30, 2014 | Samsung DV328AEW Electric Dryers
DV328AEW/XAA dries one load and quits until cool
Typical 'motor over heat' or weak thermostat problem. Try starting the dryer just after it over heats. What happens..A humming sound?...motor is overheating and seized up....if quiet, could be motor as well. Check that your dryer vents are open and clear.
Oct 15, 2013 | Samsung Dryers
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
Samsung electric dryer model # DV328AEW not heating up to dry clothes
heatman101.,//';
Mar 09, 2011 | Samsung DV448AEE Electric Dryer
Dv328aew/xaa dryer not heating
If the fuses at the panel are ok then could be the heater, thermostats, sensor or control.
Dec 07, 2010 | Samsung DV328AE Electric Dryer
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
Dryer spins but no heat
Did you check the power coard where it connects to the dryer? Start at the source. Make sure that you have at least 110v on each line. The dryer will tumble on 110v but requires 220v to heat. If you have 220v then check the t-stat and thermal cut-out on the blower. Check all wires for loose or burnt terminals. If all that is good it may be a bad motor or timer/control. I'm happy that you have a meter.
Good luck.
Dec 17, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
844 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
