Question about Amana Microwave Ovens
Need a manual for the Amana convection ACO1180AB also can you replace the round piece (looks like cardboard) in the very top of the oven?
5 Suggested Answers
SOURCE: Amana Radarange Microwave/Convection over the stove
aco1560ac is the model #.It is an araman I need to know how it hangs on wall
Posted on Feb 03, 2008
Illeagle
  • 525 Answers
SOURCE: IS MY MICROWAVE NOW UNSAFE TO USE - CAN I DO OWN HOME REPAIR?
It sounds like what you are describing is called a "waveguide cover". You can purchase a replacement from a local parts supplier, or on-line at www.repairclinic.com. It is very easy to replace.
Posted on Jun 30, 2009
  • 178 Answers
SOURCE: Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Posted on Sep 12, 2009
SOURCE: For the sunbeam microwave sgb8901,
I am also having this same problem i dont know the solution yet, but when you figure it out please let me know, or if i figure out i will repost =]
Posted on Oct 11, 2011
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
Arcing or sparking. Need new piece (has grease on cardboard(?)cover.)
Hi
You will need to purchase a new cover. I don't know where you are, but in the US you can obtain Amana parts through Comserv 866-426-2621 or in the UK through thier distributor on 0845 1413000
Hope this helps
Jan 07, 2010 | Amana ACM2160A Microwave Oven
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
I need the little cardboard piece that hangs on the top of the microwave for my Emerson. Where can I get this that fits there?
Take a piece of cardboard and cut one out. You probably won't be able to find what you're looking for.
Jan 19, 2009 | Microwave Ovens
Amana converction express
hi my name is mark, try this link http://www.managemyhome.com/mmh/products/ManualSearch.action hope this helps. if you happy with answer please leave a rating.
Dec 28, 2008 | Amana AMC6158B 1000 Watts Convection /...
Micro/convection stops every minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door could be jammed.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Many models stop after 59 seconds if there's a problem with the damper saystem.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for your Sharp model and have uploaded them to our site here and here to help you.
You will need the
free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
For the Amana, There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts for the Amana by entering your full model number here.
The Amana's damper switch is called "interlock switch" and is located at ref# 15 in drawing #5. The damper motor is ref # 22.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Nov 29, 2008 | Microwave Ovens
Amana ACE208 doesn't work with a message 'door'
The door latch receiver has a spring action lever (inside) that is made out of plastic and cracks or wears through. You need to remove the cover and remove the two screws holding the door latch receiver. Now you can switch the top and bottom piviot switchs, putting the top one lower and the lower one on top..make sense? you"ll understand when you see it.
Feb 26, 2008 | Amana ACE208 Convection/Microwave Oven
Volume control
no there is no way to adjust the alert they come already factory set.good luck
Apr 16, 2007 | Amana ACE208 Convection/Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
