Question about Durabrand PDV-709
Battery usage Is there a way to use batteries in this player?
    Problem Solver:
  • 8 Answers
Nope. The OEM battery is specifically designed to fit.
However, since there IS a DC jack on the side (for the AC adapter and/or Car cable), you might be able to locate a small 12 volt rechargeable battery pack into which you'd plug your Car Cable. I'm thinking along the lines of something like one of those car battery jump start units, but much smaller. I have seen them over the years, but without a search I can't recommend anything at the moment. Try Ebay, or Google "batteries." You'll find a bunch of online battery stores that just might have what you need.
Posted on Aug 10, 2010
I know this is not a normal question as it is not a problem as such but I am trying to find out the battery life of a Thomson portable DVD player code DP900T and cannot find it anywhere. Would you know...
hi,
Do you mean usage time with one charging then you will get approximately 2.5 hours at full charge.
If you mean the how many years the battery will work with out replacement then it will depend on the way of usage. Also the company itself cant tell how many years it will work perfectly.
Jun 07, 2011 | Thomson Televison & Video
My philips gogear 8gb mp3 player cuts off when i take my charger out of it
Your battery must be exhausted.. That happens when rechargeable batteries have reached their maximum usage. I advice for you to purchase new batteries.
Thanks for using fixya!
May 31, 2011 | Cameras
I charged my 2GB SENSEI mp3 player for more than 4 hrs...but still its not working even for 10 to 15 mins......so wat is d time required for full charging....
Depending on the age of the mp3 player, the battery may be shot and you may need a new one. mp3 players tend to get heavy usage and the batteries can die and get burnt out quickly especially if they are not charged properly. Try draining the battery until it can no longer turn on. Then charge your battery for 6 hours. Good luck.
Mar 01, 2011 | Computers & Internet
All of a sudden it will not turn on....nothing...when plugged into the usb...it say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
Dec 20, 2009 | RCA M4204 MP3 Player
My battery only last 7 hours instead of 8 hours I have only had it a week
Battery drainage can be caused by many ways. Although if the manufacturer states that it can play 'up to' eight hours, then it's possible with heavy usage, bright screens and powering on & off the device may possibly shorten the battery life.
If your mp3 player has the option, you can always dim the screen brightness, let it go into blank screen after few seconds, and do little to conserve the battery. It's not too bad considering you're only one an hour short. I'd be concerned if you were getting less than half of what the manufacturer states.
Nov 07, 2009 | Coby MP-610 MP3 Player
IFP-395T (AA Batteries)
Probably a hardware issue, but the issue could also be with your USB port - make sure that there are no yellow exclamations next to the usb port in the PC device manager.
The battery indicator might not be stable during the following activities because they use large amounts of power:
1. The backlight of the LCD
2. Volume change
3. Pressing function keys and buttons
4. Reading the CD or files (Loading data to the memory)
The battery indicator shows the life expectancy of the battery based on current power usage. During these high power usage activities, that may only last a few seconds, the indicator will obviously show a lower level on the battery indicator. Once the high power activity has ended it will show a more accurate battery level.
Sep 26, 2007 | iRiver iFP-380T MP3 Player
Axim Battery
The battery that comes with Axim is the standard 1440mAh; an extended battery with something like 3400mAh is indeed available as an option. According to some reviews of Axim, the standard battery is good for 8-10 hours of normal usage. One review said they played MP3s non-stop for 6 hours 22 minutes before the MP3 player stopped because of not enough power, but Axim still had another 16% on the battery which was good enough for about another full hour of standard usage. Audio and video will both cut down on how much you can expect from the battery, video much more so than audio. If you are planning on watching full length movies on an airplane from a 1GB Microdrive, I think getting the extended battery would be a good idea. I'll give this a try myself as soon as I get my Axim, which should be... drum roll... the day before Xmas, according to Dell.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Durabrand PDV-709 Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
