Question about Nikon D80 Digital Camera with 18-135mm Lens
Inadvertanly set delay and can't figure out how to reverse it.
Inadvertanly set delay and can't figure out how to get it back to the original setting.
    Champion:
  • Nikon Expert
  • 225 Answers
Are you speaking of "Exp. Delay mode"? That is found in Custom Settings Menu number 31. Page 99 in the D80 manual.
Posted on Aug 25, 2010
I've been looking for the self-timer on the Polaroid i1236, but I can't seem to figure out how to find it in the settings and set it up. The help would be great. Thank you.
The self-timer is in the drive mode setting.
From the Record menu, select Drive Mode. Use the up/down keys to go through the
selection. Press the OK button to save and apply changes.
The self-timer choices are ten-second delay, two-second delay, and double, which takes one picture after a ten-second delay and takes a second picture two seconds later.
Nov 24, 2010 | Polaroid i1236 Digital Camera
Repeatedly press the shooting mode button on the upper-right side of the camera (marked with overlapping rectangles) to select the desired shooting mode. If that doesn't work, hold down the button and turn the main command dial (on the back) to cycle through the modes.
The available modes are Single frame (letter "S" in a rectangle), Continuous (overlapping rectangles), Self-timer (one-armed clock), Delayed remote (self-timer above remote), and Quick-response remote (remote).
Jul 30, 2010 | Nikon D80 Digital Camera with 18-135mm...
Why do all my indoor shots look grainy and kind of foggy? I dont know if i hit a some kind of setting or what.
Make sure that you haven't inadvertanly set the camera to "Macro: a single flower on most dials" that will do what you described.
Jul 07, 2010 | Cameras
When i push the button to take a picture, the camera delays for about 3 or 4 seconds before it actually take the pic. Why does it delay?
There could be several problems like:
1)The focus.
2)Self timer set to 2sec or 10sec.
3)very slow shutter speed set.
Make it as a 10 or 20 second delay on the self timer .Your problem here could be that the settings are not right. Go to the menus and reset all to original or default. Then set menus the way you like. You may have a slow memory card, try changing to a faster card, and test it.
Thank you!
Jun 19, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
How do I use and/or set the timer on the Power Shot A530
In the shooting mode, press the Func/Set button. Scroll down the icons to the 'drive mode' icon (a square). Then scroll right to the icon showing a circled 2 (2 second delay) or a circled 10 (10 second delay). Press the Func/Set button to select.
To return to normal, use the same procedure, but select the square icon (single shot).
Sep 18, 2009 | Canon PowerShot A530 Digital Camera
Canon Powershot s1 is delay
Once you've set the self-timer, start it by pressing the shutter release button as usual.
Jun 09, 2009 | Canon PowerShot S1 IS Digital Camera
94' jeep grand cherokee trans. delays in reverse
Hi ray_c_brown, This pause is determined by a time lag test, and you can check this yourself with a stop watch.Engagement time in "D" range should be a maximum of 1.2 seconds and the engagement time for reverse should be a maximum of 1.5 seconds. So with your vehicle warmed up and assuming curb idle speed is correct set the park brake,make sure ac is off (air cond) shift transfer case to 2H or if it is a NP249 transfer case leave in 4H,put your vehicle into neutral and set your stop watch shift to Drive and record time repeat this a couple of times and do the same with reverse,as you said the delay is with reverse so if it takes longer than 1.5 seconds here are a few things it could be:shift cable adjustment,low line pressure,worn direct clutch, first/reverse brake worn or a worn or damaged overdrive clutch.Hope this helps you good luck :)
Nov 11, 2008 | 1994 Jeep Grand Cherokee
Self timer
1. Press the Func/Set button
2. On the left side of the LCD, scroll down to Drive Mode icon (usually a square, third item down)
3. Use right arrow key to select clockface with 2 (2 sec delay) or 10 (10 sec delay)
4. Press the Func/Set button
Now whenever you press the shutter button, the camera will delay 2 or 10 seconds before a picture is taken. Use the same steps to go back to normal (square icon) drive mode.
May 01, 2008 | Canon PowerShot A710 IS Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
