My cold water on my whirlpool estate wont turn on only hot water works. When i set the cold /cold water water wont turn on . On hot/cold it turns on but only hot water comes out.
  • 171 Answers
First thing to do is of course check to make sure the cold water is turned on.  sorry i had to put that in there.  you can take off the cold hose at the washer and check to see if there is a blockage such as calcium deposits which can block the line. if all that is clear then you will probably need to have the inlet valve replaced.
Posted on Jul 30, 2010
No hot water getting into Estate topload washer. Have to turn off cold tap completely to get hot washer for wash cycle. Then turn cold tap back on for rinse cycle.
One simple thing to try is to clean them screens on the water valve. Remove the hoses and get the screens out. Give em a clean or chunk em and wash on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 30, 2011 | Estate ETW4400VQ Top Load Washer
Rinse cycle does not work. everything else does
Verify water flow to BOTH hot and cold inlet valves. Dirt can plug screens and Dad sometimes turns off water, trying to save $$. BOTH inlet valves need water flow.
Jun 11, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Bought a hot water heater made by whirlpool for 2 weeks only had enough hot water to fill 1/4 of the tub then the water turned cold . They have replaced the hot water heater and still has same problem....
The down tube in the tank has fallen off or the hot and cold lines are reversed at the tank. I'm going to assume it is gas , if its electric you need to test the heating elements for continuity and temp settings. as well as the down tube in the top of the tank that sends the cold water feed to the bottom of the tank..
Mar 13, 2011 | Whirlpool Home
Water continues to fill into the washer drum on the spin cycle.
Hi
You could have a stuck solenoid valve
Try this: Set the water temp on cold. Turn on only the hot water.
Does hot water try and fill the drum?
If so then there is a problem with the hot solenoid.
Next set the water on hot. Turn on only the cold water. Does cold water try and fill the drum ?
If so then there is a problem with the cold solenoid.
Jan 05, 2011 | Whirlpool LTE6234D Top Load Stacked...
My whirlpool washer is not allowing watert to flow
first of all, you probably had the hoses reversed.  secondly, by turning off hot you may have damaged fill valve / solenoid and it now might need to be replaced.
Jul 24, 2010 | Whirlpool Washing Machines
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Hot and cold water mixup
Switch the lines and grin and bear it!!
Jun 20, 2009 | Whirlpool Washing Machines
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
No cold water. I have hot, but not cold.
Turu off the cold water to the m/c, and hold hose into a bucket or something similar, turn water back on again, and see if you have a supply, if water there, then check the filter i the valve it it has one, and clean if req'd, reconnect hose and try again, if still no cold fill ,then the inlet valve is probably faulty, you will need to replace same.
Plz rate this solution.
Thanks.
Dec 25, 2008 | Whirlpool Washing Machines
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
