Question about Dometic RM2652 Refrigerator
Freezer freezes refer wont get cold - Dometic RM2652 Refrigerator
    President:
  • 1,099 Answers
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal,
you didn't give me much...that said, try a full defrost of the unit. You probably have a buildup of ice caused by condensation. This is probably because the door seal isn't doing its job well. If the coils that do the cooling are not exposed, you must either wait for a full defrost...about 2 days or figure out how to remove the covering panels and go about melting the ice. If you do, be sure that any heating equipment...like a hair dryer...be kept from getting wet. If this happens again, you probably have low gas levels in the box...you'll need a tech. Be sure you unplug the box.
How to check for low gas: Once the unit is defrosted, start it up with the coil covers off...after about 5 minutes, you should see an even coat of frost at both ends of the coils. If not, wait 5 minutes more. If still not, you're low. Alternate method: Go round back and find the compressor...the big black thing. It has a couple of pipes sticking out. The largest is the suction line. Start the unit. Wait about 5 minutes. It will frost up. It should either get dry or form liquid condensate on it if you've got enough gas. If it stays frosted, you're low.
Hope this helps.
Posted on Jul 30, 2010
5 Suggested Answers
  • 1122 Answers
SOURCE: my frigidaire refrigerator does not
ONE OF FOUR THINGS IS HAPPENING,YOUR FAN IN FREEZER HAS STOPPED,YOUR DEFROST THERMOSTAT IS BAD,YOUR DEFROST HEATER IS BAD,OR THE DEFROST TIMER IS BAD,REMOVE THE FREEZER BACK PANEL AND YOU CAN CHECK ALL BUT THE DEFROST TIMER DEPENDING ON MODEL MOST ARE IN THE FRIG.,LET ME KNOW-MIKE
Posted on Jul 07, 2008
  • 40 Answers
you have a defrost problem either a bimetal thermostat, defrost timer or a heater. open doors and unplug unit for 2 days to let defrost it will work great for a week or so. not to costly to fix either way
Posted on Feb 23, 2009
aviral_srms
  • 1216 Answers
SOURCE: Freezer freezing very cold on
Sounds to me like a defective fan.Please check the fans whether they are working.
Next you should do is to clean the coils at back of your device if they are dusty.
Also check your freeser ,if it is overfilled please make space for air to circulate in fridge and don't overfill any shelf.
Check these and reply me.
Posted on Apr 05, 2011
Kenmore elite bottom freezer refrigerator error code er rf
buy a new unit the least costly you can find .
Jul 17, 2015 | Kenmore Refrigerators
Hi I have a Maytag model MFI2568aes my vegetables and fruit chillers are freezing everything. Chiller control is moved to the top which is cold, levers on chillers are far right. HELP. Gilbert cell...
Air is controlled by the damper located in the top portion of the refer section behind the ice maker assembly. Make sure the damper can open and close. If stuck open, this would allow air to enter all the time and cause freezing. Most likely the issue is found the the damper has failed to close when needed causing freezing. Double check the temperatures to the freezer, it can"t be any lower the -2 degrees, but you can raise it to 2 degrees to see if this corrects your temperature issue. The software was designed to bring in air from the freezer to produce ice first, then migrate to the refer section, if too cold for the freezer it would migrate into the refer causing freezing of veggies and produce.
I hope this information helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 16, 2013 | Refrigerators
Wont freeze or get cold
it has cooling problem or somewhere of wires are ligued.so you face this problem.
Mar 21, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Freezer not freezing like it should
Yes that is hte panel in which "skeeter 140 " was refering
Jan 14, 2009 | Frigidaire FRT18FS6C Top Freezer...
Dometic RM2652 Refrigerator Logo
289 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
