Question about Car Audio & Video
The amp is hooked up correctly and it goes into protect and stays there. if i levae it like that for over 30 seconds it will start to smoke a little bit..
Lm /.jbbb
Posted on Apr 24, 2008
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
Recently my subwoofer blew out & a friend hooked up a Bose subwoofer that goes to a computer,i think it was defective because when he hooked it up something inside my reciever just started to smoke so...
Put a fork in it, it's done. Take it a tech to give it the sniff test and determine the extent of the damage.
If you want a specific answer regarding a code you need to provide a make and model number. I doubt any code will negate whatever caused 'smoke'. No UNDO buttons on this stuff.
In the future refer to manuals for speakers and amps before randomly attaching parts of other brands or packages' all-in-ones'. They're usually desigend to be used exclusively as one unit and are not generally interchangeable.
Mar 23, 2011 | Audio Players & Recorders
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
It plays for a couple of seconds and then runs over to protect mode and stays there
usualy means there is a problem with the speakers, they may be wired wrong, short in the wires or the voice coil in the speakers themselves. best way to trouble shoot is to power the amp with no speakers hooked to it, if it only goes ito protect with the speakers hooked to it, the the problem is with the speakers, not the amp.
Aug 17, 2009 | Kicker KX400.1 Car Audio Amplifier
Amp Turns off after 30 seconds of song play.
Check your ground and make sure it is grounded to metal in your car with no paint. Also, make sure you are running 4 gauge power wire. Another possible cause could be that the ohm load is too low on the amp. Also, if your car battery drops below 10v it will send the amp into protection.
Apr 15, 2009 | Kenwood KAC-8103D Car Audio Amplifier
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Protect mode
The only thing to try would be to remove the sub wires form the amp and see if it still goes into protect. If it still goes into protect with the subs unhooked then the amp will require repair.. If it doesent go into protect then check to see if you have a shorted subwoofer. also make very sure that you have a good clean bare metal tight ground connection to the body of your car. People forget that step all the time.. Did you do your setup with the correct ohm load? Most of these amps will fail if the subs are hooked up incorrectly(too low of a ohm load). If the amp has a lowest possible ohm load rating of 4 ohms... but you have a pair of 4 ohm subs.. you hook them up togther at the amp.. both positives togther- two negatives togther.. because it "bumps harder" that way.. Then you now have a 2 ohm load on the amp... The lower the ohm load you put on a amplifier the more it will output. The problem when people do this is that the amp outputs more current then its internal parts are rated for and the output transistors (usually) fail.. most amps will not fail if installed correctly.
Aug 20, 2007 | Pyle PLA2180 Car Audio Amplifier
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
