Question about GE Microwave Ovens
Igniter keeps clicking when gas is off - GE Microwave Ovens
  • 532 Answers
You can solve the problem by cleaning off the igniters.
Unplugged the power. Then take a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similar to do the scraping. you will notice a shiny surface underneath. Then go ahead and scraped and brushed clean the mating surface where the spark travels. You will then vacuum up the mess.
Your burners will work great after this.
Thanks for contacting Fixya.
Posted on Jul 30, 2010
The gas stove model 317b6034 keeps clicking like when you turn on the burners what might be the problem
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 25, 2011 | Microwave Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
The igniter keeps ticking when burners are turned off.
heatman101
Jul 25, 2011 | Microwave Ovens
HELLO I HAVE A WHIRPOOL SUPER CAPASITY 465 THE SPARK IGNITE WONT STOP CLIKING AND ALL THE BUTONS FROM THE STOVE ARE OFF, WHAT CAN I DO
heatman101
Jun 06, 2011 | Microwave Ovens
Waterford hob igniter wont stop pinging
heatman101
Apr 24, 2011 | Microwave Ovens
My Jen-Air Gas cook top ignitors keep clicking when one or all 4 are lit can this be stopped
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
heatman101
Apr 16, 2011 | Microwave Ovens
I was cleaning my gas stove near the knobs and now it keeps sparking until i turn it off. will it eventually dry up and work again?
Usually but not always....
Gas Range Repair
heatman101
Feb 06, 2011 | Microwave Ovens
My left front burner igniter stays on even with the knob in the off position, whats wrong?
Gas Range RepairBurners Keep on Clicking
heatman101
Nov 11, 2010 | Tappan Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
