Question about Tomtom ONE GPS Receiver
My tom tom one xl keeps saying poor gps am i in as buildind? I have tried updating it and also the tomtom gps fix but to no avail, also have reset it too
  • 3 Answers
It sounds like the GPS Fix file is corrupted. You can fix this by connecting your GPS to your computer. The GPS will then become an external drive. Search the GPS folders for one called ephem and delete the contents, not the folder. Run TomTom home again to update the device. It should re-install the GPS fix file, which should correct the problem. It will take about 5 minutes for the TomTom to find what satellites are available when you turn it on again, so be patient.
Good luck
Posted on Aug 04, 2010
  • williamjo497 Sep 14, 2010
    With the Citroen C5 it has a thermal front screen that blocks the signal.
  • 63 Answers
Make sure you keep it up on the dash, and that you arent trying to use it in a garage.
Posted on Jul 30, 2010
Tom Tom 540 can't find satellite signal for past hour
The problem can be fixed by resetting the tomtom one xl gps receiver. Tomtom one xl gps receiver is common with this problem, after resetting it, it is most likely it will happen again. So be ready to keep resetting over time.
It most like is as a result of bad strength to search and detect the satellite. So you have to adjust the antenna also to a area where it can pick signals easily. This is quite uneasy because the areas to locate the satellite varies in terms of the location you are.
Software update will not fix this problem as well as the quickgpsfix, so the bes solution is for you to keep resetting it. Hope this helped. Thank you for using fixya.
Jan 20, 2011 | Tomtom GPS
My tomtom one XL.S keep reading,no maps found. All I need is a map of the U.S.
I would shut it off and turn it on. If it persits, just hit the master reset in the back. But what you may want to do is update the maps on tom.tom.com
Sep 19, 2009 | Tomtom One XL GPS Receiver
Tomtom xl says no maps available after installing new update from tomtom home
when your registered it with tom tom they take note of your maps
check your online tom tom account and it should let you re-download your maps.
I you backed it up to your computer you can also restore the maps from there with the tomtom home software
Aug 22, 2009 | Tomtom One XL GPS Receiver
Need to up date tomtom xl less then 1 yr old?
download tomtom home from www.tomtom.com install your cradle after the download then your tomtom and with a bit of luck, the update section will automatically select the updates you need. good luck
Aug 04, 2009 | Tomtom XL 330 Car GPS Receiver
My Tom Tom One takes a long time to pick up a GPS signal (30 to 45 minutes)
You might want to try updating your TomTom through TomTom Home. It loads something called "QuickFix" onto the TomTom, which I guess tells the TomTom where GPS satellites are going to be. I get a fix in about 5-15 seconds if I keep this updated, otherwise it takes a few minutes.
Aug 01, 2009 | Tomtom One XL GPS Receiver
I have a Tomtom XL and lately its taken forever to find gps signal, i tried everything like resetting it which works for a bit but then has that problem again. Can someone help. thanks in advance
i work as a truck driver on a small fleet of 7 vehicles in the midlands UK
3 of us have Tom Toms, the others have medion, navman or garmin.
ALL the tom tom users have been experiencing GPS problems this week ( june 21 onwards ) whilst the rest of us have seen no change in GPS satelite availability.
In addition, a friend who uses a TOM TOM One XL in another part of the UK has also had same problems.
Its a TOM TOM problem generally it seems, and NOT your particular piece of kit.
Jun 26, 2009 | Tomtom One XL GPS Receiver
Poor gps reception on tom tom one
my tom tom one third edition connects in less than 40 seconds from ca cold start.
first reset everything then connect it to your computer and upload all the needed updates to it( especially the QUICKGPSFIX feature that speeds up the time it takes to connect to satellites.
after that. go outside and wait for the signal to be acquired ( less than 2 minutes)
Jun 20, 2009 | Tomtom One XL GPS Receiver
MY TOM TOM 330 BOOTS UP BUT IT FREEZES AT THE CAR IMAGE WERE IT SAYS TOMTOM XL AT THE BOTTOM IT WON'T LOAD INTO THE ACTUAL GPS
Try to hard reset the unit press and hold the reset button for 10 seconds and then if still not work check if there is a latest firmware update and also make sure to properly charge the unit for 3 to 4 hours.
Jun 09, 2009 | Tomtom XL 330 Car GPS Receiver
Tomtom not finding gps satellites
i had exactly the same problem, i dont really know how i solved it but first i thought it could be a memory problem slowing the gps signel so i reset the tom tom to factory settings then downloaded the updates from the tom tom home program of corce i lost all my destinations but i didnt want to do a back up just incase one of the updates had a virus or something so if u want to keep them i sugest u write them down first.and then i got a safty pin and pressed the reset button underneath where the memory card goes twice the second time i held it down for about 10 seconds then i looked for updates again from tom tom home. after that in tom tom home there is an option where u can operate your tom tom on your pc so i tryed that and i put in a destination on the pc and clicked on demo tour so i watched the route first it was a bit slow but started to speed up a little. after it had finished i un plugged the sat nav and went for a walk with it around the house soon as i went out side and set a destination it found 6 gps signels,make sure yhe battery is charged to at least half. well i hope anyone who follows my steps gets the same results, thought i lost 200 quid cos i have had it over two years and its only guarenteed for 12 months. well good luck.
Jan 07, 2009 | Tomtom One XL GPS Receiver
Tomtom ONE GPS Receiver Logo
236 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
