Question about Hayward Navigator Pool Cleaner
Does not seem to move easily and sticks at top
  • 640 Answers
With these pool cleaners, I would first check your water flow to make sure you are getting sufficient pressure to propel the cleaner. Next, check the throat of the cleaner for obstructions that would restrict movement. Make sure that your shoes and wings are not worn. Make sure you have proper tension in your rear flap. Adjust it and see if you get different results. Make sure all of your screens, turbines, etc. are clear and free of debris.
Posted on Oct 08, 2010
If you move the shifting lever in my truck it doesn't move the gears. I took the lever out and it seems to be missing a piece. It goes in the middle in some google pics it seems to be black. Any help?
If you have a stick shift that goes directly into the top of the box, the problem could be a missing pivot pin in the ball at the bottom of the stick
under that ball and directly at the end if the stick is a smaller ball that should have a plastic cup attached
that cup fits neatly into the selector rail slots
if it is missing ( probably broke up and fallen to the bottom of the box) the shift will be very sloppy
if the pivot in the turret is missing ( probably fallen out on the raid) the lever has no leverage point to move the selector rails
Oct 19, 2015 | 1985 Ford Ranger
Oldsmobile intrigue problems
make sure the throttle cable is not damaged and moves easily by disconnecting the cable at the throttle body and move the cable back and forth it should move easily and no restriction in movement. if this is good then you can try to clean the throttle body as it gets dirty inside and can cause the throttle to stick.
Jul 13, 2014 | 2000 Oldsmobile Intrigue
Steering levers difficult to move
Add hydraulic fluid if it uses hydraulics and change or add oil if needed. grease up any and all grease ports. If the problem continues you might want to have a professional come out and look at it.
Dec 29, 2012 | Garden
Driver's window stops coming up half way up.
When you pull up does it move easily or is it fairly stiff? If it moves easily than its possible the regulator is bad ( the part the motor attaches to). Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 22, 2012 | 2004 Pontiac Montana
Head light replacement
2 methods......1st, drivers side, stick your hand down by the alternator and then move over behind the headlight. You'll feel a 3" round rubber boot, just pull it off. Twist the bulb out and replace.
Passengers side- take the top of the air cleaner off, at that point, you can easily get to the rubber boot and bulb.
2nd, involves removing the grill, I don't like this method as the grill can crack or break easily while trying to pull it off.
Mar 03, 2011 | 2004 Chevrolet TrailBlazer
Rear brake sticking
Try oiling (lightly) the brake shaft where it goes into the rear wheel hub and where there are moving pivots and bushings. Make sure the spring on the pedal arm returns the arm smartly. Worst case, remove the rear wheel and grease lightly, the brake cam which sits between the ends of the brake shoes. Wipe out any brake dust from the brake shoes and drum. Hope this helps!
Jul 25, 2010 | 2003 Suzuki GZ 125 Marauder
MTD LAWN MOWER PART # 903-0382 AXLE Assembly: FRONT: cant seem to move stick to choke or idle postion i...
You need to get some oil to drool down the cable on the inside if you can, it will free it up. Try blaster, the stuff works great. Some of the cables are just metal clad and the oil will penetrate right through it, but the plastic coated ones you have to get in from the top, hope this helps.
May 06, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
The moving stick wont stop moving
I was having a problem with my internet connection and it seemed to started after analog was acting up. I decided to take off the top cover and i carefully cleaned area where the anaolog made contact. I also noticed that when i left the screw loose the analog stick moved around on its own. Hope this helps
Dec 31, 2009 | Sony PlayStation Portable (PSP) Console
My dishwasher is broke, kenmore model number 5871434960. It does not seem like is recieving water anymore. I have checked the immediate water valves upstream. They are open. Any Ideas?
relay switch in float valve may not be working or your float valve in washer is damaged or sticking try to move the float vallve it should move easily if it does check the relay under float valve
Dec 15, 2009 | Kenmore Dishwashers
Won't spin after drain seems it has rough spot
Its the water pump- a shiney metal retainer is partially out and rubbing against its housing.
Mar 29, 2009 | Maytag HAV3460AWW Top Load Washer
Hayward Navigator Pool Cleaner Logo
54 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
