You must look for villas that are near to the beach area for getting your most of the time near the beach with your pockets full of sand. You can book your villa for your memorable times you can get it from Location Villa Ile Maurice. This also offers many other offers and shopping sites that will help you to get all the materials of your need without going out and miss the time that you may have utilized in the beach.
Try and replace the fuse that was found damaged. if the fuse blows out again there are errors in the main power supply whcih is the SMPS unit.
Check this link for some tips.
It will be inside the unit main panel. Turn main power off and remove the main front panel. The fuse will be located on or near the fan control board. Typically they are a flat agc type fuse. 3-5 amps. The problem will be that if the fuse is blown -there is a reason for it. They don;t just wear out and blow. Look for frayed wires around the outside unit and in the thermostat to make sure you dont have a short. Otherwise, you will just blow the fuse you replace.
Look for bad caps first and main AC fuse, yours is very similar to VA702. If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Pry the frame from the front of panel and you should see the circuit board for the buttons. Unscrew that and you should be able to see the board itself and turn the monitor on from there. I placed a small plastic piece between the button and the board and it works. Hope this helps.
