Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
PC nor reading external WD (Western Digital) USB hard drive
    Brigadier General:
  • 10,406 Answers
Try connecting it to another computer, to see if your computer is the problem.
Try a different USB cable between the unit and your computer.
If it is still under warranty (one year?) then contact W.D. to get an RMA (Return Materials Authorization) -- then, ship the unit to them, for repair/replacement.
If the warranty has expired, open the case, disconnect the USB-to-disk-drive adapter, and connect the disk-drive as a "slave" drive in some desktop computer, to see if it can be properly "detected".
Note that W.D. has a "Customer Loyalty" program -- give them the serial-number from the disk-drive, and you get a good discount on the purchase of a new Passport from their web-site.
Posted on Jul 30, 2010
4 Suggested Answers
ohms
  • 1879 Answers
SOURCE: Western digital ext hard-drive not recognised on PC
-go to device manager
-click view -> show hidden devices
-locate western digital under USB devices
Posted on Sep 17, 2009
lock123
  • 6831 Answers
SOURCE: external hard drive don't install
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
SOURCE: I HAD Western Digital My
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
Posted on May 24, 2011
Recommend me branded USB drives ?
Honestly, any USB brand will cut it for you. What you want to ensure is that you are purchasing the proper version (1.0, 2.0, or 3.0) for whatever device the key will be associated with. Also make sure you don't buy too little or too much memory. But if you know all this and you just want a reliable brand, I would go with SanDisk.
Aug 04, 2015 | Computers & Internet
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
May 18, 2011 | Western Digital My Book Essential 1TB...
My WD 1tb external is no longer being read by my macbook pro, and verification and repair keeps failing. I can't erase it either.
Try out the hard drive on another computer, to verify if it's a hard drive issue or a computer issue. Then, get another hard drive, or USB stick, and try reading/erasing/recording on it from your MAC, to see if the computer is handling external data storage devices properly.
I'm not a MAC guy so I can't help out if it's your computer that's misbehaving... but if it's the hard drive that's misbehaving, then you may want to run a partition repair scan and also run a surface-level scan to make sure everything's ok. If you have a PC near by, get the WD Diagnostic utility here http://www.softpedia.com/get/System/Hard-Disk-Utils/Western-Digital-Data-Lifeguard-Diagnostics.shtml and run an extended disk test. This will find and repair any logical problems with the hard drive. After the test is over, run a SMART scan too, that will tell you the physical state of the hard drive. If it points to some parameters that are off the recomended values you may want to get all the data off the drive. I'm sorry to say, but the 500GB-1TB Western Digital hard drives, especially the Green Line series, proved to be a very silky line, fragile, unreliable.
If you opt for a new hard drive, I suggest that you keep the WD casing, and stick a Samsung or a Seagate hard drive.
If you found this post helpful and informative, please vote with a Thumb Up. Thank you.
Jan 18, 2011 | Western Digital My Book Essential 1TB...
How do i use a wd external drive 500 gb on a mac & pc
The MAC can read and write PC files but not the other way around.
To do this the USB external hard drive needs to be formatted using the PC and formatted in FAT32.
Once this is done then you can exchange data between the MAC and PC.
Nov 03, 2010 | Western Digital My Book Essential Edition...
WD 1 TB is not working my laptop is not reading it spin for a sec and stop what would be the problem please help . Thanks
The disk-drive is "dying". If the WARRANTY (probably one to three years) on the W.D. drive still is VALID -- it probably is, you should contact Western Digital, and get it replaced, by exercising the warranty.
Sep 24, 2010 | Western Digital Elements powered by WD 320...
Wester digital external is on computer not reading it
Is the drive operating normally except for the lights not working correctly?
Nov 22, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Mac will find wd hard drive PC will not
The Mac disk format cannot see or read by a PC, the PC can see the external drive as a device only.
The way around this problem is to format the external drive with the PC, now you can fransfer/copy files to the external drive and when you plug it into the Mac, the MAC can read PC file formats, this also applies to USB memory sticks.
Aug 02, 2009 | Western Digital My Book Essential 1TB...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
273 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
