Question about GE Monogram Refrigerator Built-In Side-By-Side 48" Non-Dispenser
Water dripping down freezer side above ice compartment
GE Monogram SbyS - FREEZER
Water is constantly dripping down from the roof of the unit freezing all down the entire left freezer side. It's above the ice maker compartment though. Any suggestions would be greatly appreciated. Thanks.
  • 3,083 Answers
There is a good blog about a similar problem, but he explains how to get at the water inlets to check them, here it is:
http://www.applianceblog.com/mainforums/ge-hotpoint/5899-ge-monogram-side-side-leaking-bottom-right-door.html
If water is dripping down from the roof, it's either spraying up somewhere, or you have a bad line possibly.
First thing is to find where that water's coming from and fix it. That will probably get it working again.
Here's another good answer that you may be able to notice and fix yourself someday, just for future reference:
http://www.applianceblog.com/mainforums/ge-hotpoint/16185-ge-monogram-36-s-s-freezer-leak-ice-dispenser-chute.html
You could have a strange problem like coils icing up then defrosting, but I can't see how that would cause the water on the outside of the unit.
Check the coils for ice, and if you have that problem, you could have a control board, solenoid, or fan problem, which there are many good fixit articles on google if you need specifics.
Good luck, and hope this helps.
Posted on Jul 30, 2010
  • snyderman3 Aug 04, 2010
    Sorry to respond so late. How do I access the silver box that is riveted shut above freezer compartment to check inlet lines, etc. Thanks for your help.
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Temperature Cycles Inconsistently in Freezer and Fridge
Possible thermister our main board. Would need take readings at the board to see what the themisters are reading. If they check good then issue would be in main board
Aug 20, 2012 | GE Monogram Side by Side Refrigerator
Approx 1996 model- Have been having water leaking into freezer- water line is shut off. Now the entire freezer compartment on top is a large block of ice and dripping down. Is it possible to shut the...
No, the fridge side gets it cold from the freezer. You can turn the freezer off and use a hairdryer to thaw it out and the fridge side won't loose much cold during that time.
Your water inlet valve may need replaced to fix the leak unless the leak is a hole in the water line.
Feb 05, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
Jan 12, 2010 | GE Refrigerators
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice drips from the ceiling of the freezer
We have had the same problem for years and had multiple repair attempts at solving the problem. The simple solution was supposedly the condensation drain line was blocked, water would then accumulate on the drain pan above the freezer, and then drip down and freeze like Niagra Falls in the winter. But that solution worked only so long before it happened again. Then Sears came and replaced some heating element. That last about 9 months and it happened again. Now we are told that this is a "defective GE model" that requires an "upgrade" kit that is over $600. Basically, GE acknowledged finally the model is a piece of junk that they designed wrong, and now long after the warranty expired, we have to pay for it. We are never buying even a GE light bulb again. Good luck with yours.
Jul 07, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Water in the freezer
Drain needs be clean, Easy to say but is some work to do.
Oct 14, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram Refrigerator Built-In Side-By-Side 48" Non-Dispenser Logo
91 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
