Question about Microsoft Xbox 360 Console
There is no picture for my Xbox360. There is
There is no picture for my Xbox360. There is sound and I see the system connecting when I start it up but there is not a picture display.
    Sergeant:
    Champion:
  • 297 Answers
Yes this is the display chip overheating you can fix it with a good guide or you can send it in and they will fix it for you.
If you are going to use a good guide you can see the best HERE or send it in.
Posted on Jul 30, 2010
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Sep 09, 2014 | BenQ MP620p DLP Projector
Problem with my LG TV and my XBOX360 , there no picture and sound when i connect my xbox with hd cable.
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
Jun 09, 2012 | Microsoft Xbox 360 Elite Console
My JVC LT-32DG20J has started playing my Xbox360 and playstation2 in black and white. I have tried changing all the picture settings
What AV connections are you using? some of the older composite cables will make your game systems play black and white on HDTV's. RGB connections are different than the old standard RWY cables.
Mar 24, 2011 | JVC Televison & Video
I have sound but no video i have plugged every thing correctly
If there is a switch on your AV cable make sure it's switched over to whatever mode you are using. Sometimes if it's half-way I get no picture.
Jul 22, 2009 | Microsoft Xbox 360 Console
My xbox360 has sound but no picture it was working fine an hour before this
Your graphics encoder chip (For HD & component mode) needs resoldering to the board. These chips get very hot, and with the xbox's poor cooling system, this fails to dissipate the heat correctly.
We repair this and give a 4 month guarantee on all work.
FixMyConsole
Jun 18, 2009 | Microsoft Xbox 360 Console
Surround sound for my home theater.
you cannot output sound from your xbox to another dvd system , you can however send the sound to your tv and output the signal to a stereo or home theater system if your looking to have surround sound or looking for stereo sound , the tv should be set to video1-2-3 and thats where youll be able to have sound and picture , , thanks sincerely glenn
Mar 03, 2009 | Philips HTS3400/37 System
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
High pitch sound comming from tv!
The horizontal transistor and the flyback are damaged
Apr 24, 2008 | Samsung TX-P3264 32" TV
Connected My Xbox360 To My LCD Getting Picture No Sound (Used Xbox360 VGA Connector)
On your output cable there is a smal switch that says HD or TV. Make sure that is on the correct spot!
Jan 09, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
