Question about GE Profile JGP636 Gas Cooktop
What causes gas igniter to keep clicking when gas is off
Sounds like someone washed down theb cooktop. If the moisture traveled throughout the contacts, the clicking sound will continue while off, until things dry out. Unplug cord from wall, give it some hours, maybe even a day or so, for moisture to evaporate. This worked for me in past. Give it a try. Good luck
Posted on Jul 31, 2010
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Hope this helps.
Big D
Posted on Aug 05, 2010
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
We spilled water on the cooktop and now the igniter keeps igniting. We unplugged the top...what should we do?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 24, 2010 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
The igniter on the left front burner of the
YOU HAVE a shorted ign sw. some of these only came in a wire harnes of 4 . and if they don't change all four when in there .. mm hope this helped .. feed back pls ..
Jul 20, 2010 | Amana AKS3040 Gas Cooktop
The ignitor will not stop sparking.
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
The automatic ignition ignites with no prompting and no gas being turned on
heatman101
May 02, 2010 | Miele 36 in. KM342 Gas Cooktop
Igniter misfire
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
All 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 05, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
GE Profile JGP636 Gas Cooktop Logo
387 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
