Question about Nortel T7316E 2-Line Corded Phone
Phone does not ring
I have a nortel norstar compact ICS phone system, 4 extensions. We have moved our offices last week and since then I have been unable to get my phones to ring. The lines are all working and when I call it you see the lines are lit up but it goes straight to voicemail.
Can you please give me the sequence to turn my ringers back on or have the ringers ring atleast 4 times before going to voice mail.
Thank you for your help.
NASAIT
  • 4 Answers
SOURCE: Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Posted on Oct 29, 2008
  • 32 Answers
SOURCE: My Nortel Meridian M2008 phone will not ring
it may be turned down to low.press the program key and use the scroll bar below the keypad to find your option...hopes this helps
Posted on Dec 20, 2008
cnavarro
  • 2460 Answers
SOURCE: My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
Posted on May 12, 2009
SOURCE: nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Posted on Jun 27, 2009
consultel1
  • 860 Answers
SOURCE: How to change the prime telepone for a phone line
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key(bottom right arrow).
the display should say LINES
press the show key (top right arrow)
the display should say trunk/line use
display should say line type:public
press the next key (lower right arrow) til you see prime set
press the show button(top right arrow)
press the change key and enter in the new prime set extension
press the next key ( lower right arrow)
press the release key
Posted on Sep 02, 2009
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
http://pdf.textfiles.com/manuals/TELECOM-F-R/Nortel%20MICS%20System%20Installer%20Guide%206.1.pdf
Enter the programming mode : Feature **266344
Password:266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
Nortel/Norstar ICS phone system - Calls go to wrong voicemail on calls forwarded with NA
Check the forward no answer setting for number of rings on each extension that has ringing lines. The number of rings should be more than the auto attendant is set to answer with.
Nov 01, 2013 | NorStar Lands Phones
How do I reset my phone system? Nortel Norstar
It's simple.
On Vmail it's Ftr 983 -> pswd -> 1 -> reinstall -> yes
On MICS it's pull the power plug off and within 15 minutes -> Ftr** -> startup -> pswd
To be sure follow the users manual instructions. You can get the pdf user manual here: Nortel Norstar pdf manual
Sep 17, 2013 | Nortel Norstar Compact ICS 6.1 Software...
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Carl
Nov 23, 2012 | NorStar Meridian M7310 Phone
How to move extension numbers from office to office using nortel t7316e
There is a feature built-in to the norstar system called "Set Relocation". When this feature is turned on, you can move a working extension to an unused/activated jack and the extension, features and mailbox will stay with the phone.
Have your system administrator turn the feature on, then move up to 2 phones at a time. The phone will go through 2 bootup sessions - be patient and don't unplug the phone.
Good Luck!
Aug 10, 2010 | Nortel T7316E 2-Line Corded Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
Jul 02, 2009 | NorStar M7310 Corded Phone
Trying to make every phone ring when the main phone rings
Well that is better than most people in finding the arrows...
Ok, first you need to know the extensions that you want to program to ring, and the lines, record these numbers... if you do not know the extension numbers and actual line numbers; going to each set, and doing a FEATURE * 0 and the Intercom and line buttons this will tell you the extension number and line number (this also tells you what is on every button).
Then goto your set and put in:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the arrows that correspond.
-> you will now see “TERMINALS&SETS” and press Enter (the top right arrow key)
-> now put in the extn that you want to change (Eg. 227).
-> you should now see the extension number “227: NAME”
-> press Enter (the top right arrow key) again
-> you will now see “LINE ACCESS
-> press ENTER
-> you will now see “LINE ASSIGNMENT
-> and Enter
-> now you can type in the lines that you want to ring on this extension (Eg. 025 for line 5)
-> hit CHANGE till it says "APPR&RING" (Appear and ring means that the line will have a button on the set)
-> hit NEXT to save changes
-> press FIND to look for more lines and change the appropriate lines to appear and ring
-> then the RLS button (the little orange button) to exit programming.
After this programming is done, dial Feature * 0 and look for these new lines.
Good luck.
May 05, 2009 | NorStar Meridian M7310 Phone
Attendant still completes call after caller hangs up
Check and make sure that the disconnect clear time of ur Norstar is 800ms.
Apr 02, 2009 | Ics Norstar MICS (0x32) Modular Cartridges...
Not connecting to extensions
You have to setup the mailboxes and initialize them all before it will work properly.
Good Luck!
Jun 27, 2008 | NorStar T7316E Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
768 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
