Question about Dometic Refrigerators
I HAVE A RM3801 DOMETIC. WHEN I OPEN THE DOOR THE LIGHT AT THE TOP JUMPS FROM AC TO THE ENERGY MANAGEMENT LIGHT EVERYTHING SEEMS TO TEST OUT OK. BUT AS SOON AS THE LIGHT IN THE FRIGE COMES ON THE LIGHT ON THE BROWBOARD JUMPS. ANY SUGGESTIONS????? PLEASE THANKS COASTAL RV SERVICE IN SUMMERVILLE SC.
  • Dometic Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Sounds like you have one of "those" problems with the energy management light.
If you don't already have it the Dometic "first generation" service manual can be found here: http://bryantrv.com/docs2/docs/AES.pdf (roughly 2.14 mb / 94 pages)
This almost sounds like there is less than 11 VDC to the control panel and it is switching to the 25 min delay mode.
(OR someone has run a different power wire to the unit bypassing the ignition switch.) <-pure speculation.
As with the first and second generation series
A.E.S. models, any time the battery voltage to
the terminal block drops to approximately 9.5
volts DC, the refrigerator will switch to a
nonthermostatically regulated gas flame to
insure the unit will still provide cooling for
the customer.
As a low battery indication, the green mode switch indicator lamp will shut completely off during the voltage drop.
Also:
The refrigerator must be connected
directly to the house battery with 2 wires of
adequate capacity to avoid a voltage drop.
There could be a temp short of the door switch to the chassis that is shorting only as the door is closed. (seen this one before)
Have you tried reading just resistance on the light switch wires to the chassis as you open and close the door?
Note that pages 64 - 66 have some very pertinent data about resistance readings.
There is a service bulletin #46 out on this unit that I do not have.
Although unrelated to this problem take a look at these manuals. They are a virtual "on line" pot of gold for RV repair people. http://bryantrv.com/docs.html
Thanks for Choosing FixYa.
Kelly
Posted on Aug 01, 2010
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
I have a Dometic rm3801 it was working fine on 120v and abruptly quit cooling all lights come on compressor and cooling fan don't run. I aam unable to try it on lpg. Fridge is level and cooling fins are...
If the rear cooling coils are warm and the refrigerator is level and there is still no cooling, then you more then likely will need to replace your cooling unit. It takes a couple of hours to do but you dont need any specialized tools. Check out ArctiCold Refrigeration We keep it cold Your unit can be found on ebay at under half the price of a new fridge. Link Below 11d6ec30-092e-426d-853a-24315c5d73c1.jpg Dometic RM3801 Brand New Manufactured Cooling Units LIFETIME WARRANTY...
Sep 25, 2013 | Dometic Refrigerators
Rear AC / heating thumping sound
Yes the noise can be gear "jump" over, the teeth don't break since they are nylon in most cases. This is most often caused by a sticking/warped air temperature control blend door.
Apr 20, 2017 | 2004 Ford Expedition
Ac fan works relay comes on but compressor won't start
Sounds to me that the compressor start capacitor is the first thing I would check. You will need to get on the top of your camper and remove the outer cover. The capacitor is the part that stores up enough energy to kick start the compressor when it starts. Sometimes a capacitor will swell if bad, but not always. Mark your wiring before removal and have someone test the capacitor to see if it needs replaced. I will be here should you have any questions. If helpful please rate this solution, Thanks Sea Breeze
Here is a link to Dometic Service Manuals Click=> HERE
comparison_good_and_bad_round_capacitors
Nov 02, 2011 | Dometic Rooftop RV Air Conditioner
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
My Dometic RM2852 only cools when LP (Propane) Gas is turned on. Why won't it cool with AC only?
Good chance element is faulty. If you have a multimeter, carefully remove cover on circuit board and check voltage at terminals where element connects for 120Volt AC (hydro). The element is the round rod that slides in side of your stack and 2 black wires go from it back to circuit board. Make sure you have door open and fridge is calling for cool, otherwise you won't get voltage reading there. Best way to make sure it's calling for cool, is to open door, switch to propane, then when it lights on propane, you know it's calling for cool, then switch to AC (hydro) operation to test. If you get voltage reading from spades on board, and element isn't getting hot to touch within 10 minutes, replace element.
Jan 19, 2011 | Dometic RM2852 Refrigerator
Reversing vavle is not switching. rooft top dometic ac w/ heat pump ac is heat pump , heat pump is heat pump, everything is heat pump .any help?
Try lightly tapping the reversing valve in heat and cool mode. If the problem still exist replace reversing valve
Sep 03, 2010 | Dometic Rooftop RV Air Conditioner
Dometic RM3801. Propane ignition failure.
The older units has a 3 VDC glow coil the newer units have a 12VDC igniter.
Fromwhat your described above the next paragragh is your ignition system.
The igniter control voltages in the newer SPARK type igniters are (+) = 12VDC, (L)= high voltage lead (Spark plug voltage! I.e ruin your meter type voltage), (-)= Ground L is the lead that passes the HV spark from the control unit to the ignitor plate. The L lead should pass one heck of a hit if is workng correctly.
If not look at the HV lead to see if it is grounding out somewhere.
If the gas safety valve is not sensing gas pressure... you will not have 12VDC to the + terminal of the ignition moudule.
With the gas on and you have 12VDC at the ignition module + terminal then most likely the ignition module is bad.
Kelly
Apr 17, 2010 | Refrigerators
Travel trailer refrigerator will not get cold
Model 2652 Refrigerator The fridge has been perfct till this last trip. the auto light is on and its not getting cold no red lights and i have pluged in as well as unpluged propain is full but i see some yellow dust inside the big cyinder.we may have left the frezzer door open for a couple hour.
Jun 04, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
82 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
