How can i remove the carbon brushes to check if they need renewed.I have a Hotpoint Aquarious model no WMA34. Much appreciated Chris
    Scholar:
  • 116 Answers
You will need to remove the motor, Isolate the supply by unplugging the machine, remove the rear panel, slacken the motor fixing bolts, remove the drum belt, now remove the motor bolts and drop out the motor, un-plug the motor connections.
The brushes are at the rear usually housed in plastic one on each side, disconnect the single wire and carefully remove the housing (2 torx screws), taking care not to break or loose the brush as it is spring loaded,a typical new brush will protrude 30-40mm from the housing a worn brush will be much shorter 8-15mm and just make contact with the motor commutator. replace if necessary, check the comm for wear, refit in the reverse order.
Posted on Apr 24, 2008
Hotpoint aquarious making loud gring noises and sometimes does't start
sounds like motor brushes. physically check your motor for black power, that's a sure sign of brush wear. could be seized bearings, try spin the barrel of the washer by hand, if it's stuck/very hard to turn, thats a sure sign of bearing seizure.
Nov 10, 2013 | Hotpoint Washing Machines
Hi, my hotpoint aquarius extra washing machine wma34 drum has stopped turning it is 7 years old. there is power and the water is still going in and draining out but it will not turn. please help.thankyou.
Remove the lower back cover, check to see if the belt is o/k.
If belt o/k,then remove the motor and check the brushes in motor..
If less than 3 or 4 mm long, then they need to be replaced.
Hope this helps .
Jan 06, 2010 | Select Brands Washing Machines
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint motor problem after renewing drum bearings!
Hi dave, Its nothing you have done! It will need the carbon brushes changed in the motor as they have got low. The arcing is caused by the brushes not touching the com properly. Just change them and it will be all good.....
Mar 07, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum Does not Rotate
the carbon dust that you mention ? on the drivebelt will//may have come from the electric motor carbon brushes especially as you sy machine is 4 yrs old you can diy inspect the brushes by removing the rear panel to access motor unplug the socket from motor then slacken belt and remove belt from pully remove the motor you will see location f brushes x2 opposit each other and normally held in position ont armature of motor by coiled pressure clip like watch spring and brush has wire embedded in it and other end a push on terminal? when these brushes wear down normally the fist indication is fast spin slows then eventually no rotation of drum? over a period of time? SO easy diy to renew brushes if as above worne down /not contacting armature? cost approx £5 here in n/west uk worth investigating and diy saving ££££s $$$$s? and i hope you have good luck hope this helps/inspires you?
Oct 26, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Brushes
if replacing the brushes has not fixed then its most likely the motor is duff.
Feb 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1000 deluxe W22 washing machine
the newer type motors have carbons tht are fixed in place you would need to remove the motor and on either side will be the carbons they need to be un-screwed to be replaced
Jan 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WMA34 Where to find the motor to change the brushes
DON'T FORGET TO UNPLUG THE POWER FIRST!
Remove the lid and the motor is sat to one side on top of the drum.
Oct 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Open Questions:
Washing Machines Logo
234 people viewed this question
Top Washing Machines Experts
