Question about Lexmark X2350 All-In-One InkJet Printer
Installed driver printer works fine but unable to scan.
  • 10,421 Answers
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
ML 2240 printer not detected by Windows 7
Try installing it in safe mode.
To go to safe mode, do the following:
Restart and tap F8. Use the arrow keys to highlight safe mode with networking and hit enter. Install the driver from there and follow the on-screen instructions.
If no go, check the device manager of any question mark. There might be some outdated drivers that cause this problem. You can use RadarSync (free version) to scan your computer for outdated drivers.
After fixing all driver related issues, try installing the printer again.
I hope this helps!
David
Feb 25, 2013 | Samsung ML-2240 Laser Printer
Printer will copy and print just fine, but it will not scan from the printer or from the computer.
did you recieved error message example 1-2006. If your unable to scan its more On the software and driver issue of you printer., you need to call kodak to properly installed your software and drivers toll free 1 800 421 6699 ext 05.
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
C6180 scan unable!! conection error reported
Get the right Driver's and will work fine than recalibrate the printer. .http://welcome.hp.com/country/us/en/support.html
Jan 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scan error
Go to the HP website http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=240978&lang=en and download the driver as well as the applicatio. The scan feauture will work. make sure to select the correct Operating System. Before installing the driver and application dont forget tp uninstall the previous one and restart your computer
Oct 08, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scanner not recognizing software
I also have the same error and same 2015 printer in addition to my 7210.
Anyone figure this out? HP tech level 2 support cant figure it out.
May 23, 2008 | Office Equipment & Supplies
Scanner will not connect to computer
'Twain' only means 'Technology without an important name', as this is refering to your printer/scanner, i would suggest that you disconnect the printer and remove any driver from Add/Remove programmes. Re-install printer software/driver and re connect printer when prompted and if possible in a different usb port, if that's how it's connected. If the problem persists and the pc is unable to communicate with the printer the fault will lie with the hardware. Hope it's only a driver glitch.
Nov 27, 2006 | HP PSC 1510 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
