Question about Grundig Televison & Video
I have a grundig lcd tv vision 6 32-6930 T. I would like to know if its possible to show subtitles on movie watched over USB. If it is, how?
  • 13 Answers
SOURCE: subtitles disappear below bottom of screen
Check to see, what format the television set that widescreen etc. this may be all that's wrong with your set. If the problem persists the vertical height needs to be adjusted.  Most likely through the service menu, if units under warranty you can call Akai.  For further structures.
Posted on Oct 24, 2007
eagle338
  • 4889 Answers
SOURCE: How do I switch off subtitles on my LG 19LG30 19 in. HDTV LCD TV?
Hit the menu button, select options , select "hard of hearing", turn off and press ok.
Posted on Mar 01, 2009
SOURCE: 32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Posted on Mar 18, 2009
budmrtn
  • 11361 Answers
SOURCE: Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 17, 2009
  • 1738 Answers
SOURCE: With the Toshiba 32AV502R 32 in. HDTV LCD TV, can
It is the main menu, then there should be a volume menu and it should be in there about shutting of the volume bar.
Posted on Dec 07, 2009
CC (closed caption) won't show up on DVD movies for LG 42CS570 hooked up with standard DVD player (not Blu-ray). How can I fix that?
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
Mar 01, 2014 | LG 37LP1D 37 in. LCD Television
Pitcure and usb problem
usb is shorting out the 5 volts. as its only 2 months old would take it back to the place you bought it and get a replacement.
Mar 02, 2018 | Philips 27PT81S 27" TV
Led tv software reset
It will be best not to do anything with this TV now, as it is a new one. Contact the authorized dealer or service center to rectify the problem. Gopakumar Gopalan Google
Feb 09, 2014 | Beko Televison & Video
How to manually turn the subtitles off on a grundig lenaro tv
Turn subtitles language to... turk... o another language ...Solved problem!
Dec 03, 2012 | Grundig Lenaro 26 in. LCD TV
I have a Magnavox VCR, which I recently opened up and cleaned. Now the movies show subtitles, although they don't on another VCR. Do you know how to remove the subtitles?
Check your menu key. There may be a screen format that expands to the point, that you may see things you don't have on an older TV. Hope this helps, thanks for asking and show all hands of support!
Aug 13, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi, I have a LED TV Sony KDL 40EX600, and I can't insert subtitles when I want to watch a movie from USB stick. Do you have the solution for this problem?
When you download the movie it should have two parts folder in your sticks....
.avi ( picture folder)
and one of these as :
.srt / .txt / .sub folder
(subtitles files )
and both of the folders should have the same name ( of the movie )
So,unless you have these 2 folders, you are not able to see ant subtitles..
if it is ok,than sub comes automatically when you start the movie..
Hope this helps! Take care and please Remember to rate/vote
and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Feb 13, 2011 | Sony KDL40EX600 TV
I have downloaded a movie with subtitles using utorrent now i am trying to watch the movie on KM player but subtitles wont load!! How do i?
start movie on km player do folowing steps
1)right click on screen goto subtitles ->check show/hide subtitle.
2)load subtitle->select srt file by browising
now your subtitle will work
Nov 12, 2010 | Dell Computers & Internet
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
32LG80FR LCD TV, Arabic subtitle problem
you follow your user giude and setup language
Sep 12, 2009 | Televison & Video
Televison & Video Logo
563 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
