Question about HP Office Equipment & Supplies
HP Officejet 6500 fax report doesn't show an image of page 1
HP Officejet 6500 E709n doesn't show an image of page 1 on the Fax log report that prints following a fax transmission even though this note appears on the report:
''Image on Fax Send Report is set to On.
An image of Page 1 will appear here for faxes that are sent as Scan and Fax.''
The rest of the page is blank. Feature had been turned off but I turned it on, resulting in the above note that appears on the report. I tried resending a couple times in case the feature didn't activate right away, but result was the same.
amusedgeek
  • 787 Answers
SOURCE: Hp Officejet J5780 All-in-One
On the Officejet`s control panel, Press Setup, then press 2, now press 3.
The panel will display the choice of Off, Print confirmation on Send, Print confirmation on recieve or Print on Send and Recieve. Select your choice.
Posted on Oct 19, 2008
SOURCE: Cannot scan from HP 6500 E709n (No Scan Options)
the shortcut is:
c:\program files\hp\digital imaging\bin\hpiscnapp
Posted on Sep 04, 2009
Testimonial: "Thanks, that totally worked. I still wish i could scan from the printer, though."
  • 71 Answers
SOURCE: HP 6500 wireless printer won't print despite
have you installed the printer software on the computer. ?
Posted on Nov 06, 2009
SOURCE: Download file now RFU LOAD ERROR
Upgrading Printer Firmware
WILL SOLVE YOUR ISSUE
HP Jetdirect firmware images have an extension of *.dld while the printer
firmware images have an .rfu extension.Once imported into the repository, the files physically exist under the following location on the HP Web Jetadmin server:
C:\Documents and Settings\NetworkService\Local Settings\ApplicationData\Hewlett-Packard\HP Web Jetadmin\WjaService\config\FirmwareUpgrade
check the document from the hp
Posted on Jan 05, 2010
nonontech
  • 4737 Answers
SOURCE: my fax log report for
No, this message only reports that your sent report which should be saved in the memory is set to Off.. which means you'll not be able to see the sent report after they are sent. This will not affect your fax. Suppose if you want to print out the Fax report, you need to set this feature On, otherwise you'll not be able to view or print the sent fax reports.
You can set this On from the Fax settings, press the Settings button on the printer, locate "Fax" and go to Fax Report and set the Fax Report to On.. use the arrow buttons on the machine to navigate through the menus and submenus.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 21, 2010
How to print fax sent report
To print the fax sent reports, press setup on the printer, then press "Print Report", then select "Fax Error Report". Select the option you want (Probably "On Fax Send" in your case) and it should work from then on.
May 11, 2012 | HP Officejet 6500 Wireless All-in-One...
How get faxed confirmation HP officejet 6500
You can enable fax confirmation before sending a fax by selecting Send & Receive
Press SETUP on the control panel
Press PRINT REPORT, then FAX CONFIRMATION
Press right arrow to select SEND & RECEIVE
Press OK
Additional instructions from HP Support User Guide
Click on link and select FAX
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Feb 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp fax confirmation won't print image
Press the Setup Button on the printer Front Panel.
Go to Print Reports - Press OK
Look for "Image on Fax Send Report" which may be off.
Press OK
Turn it ON and Press OK
Your Printer will Print Image on Faxes
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | HP Officejet 6500 Wireless All-in-One...
How do I print a fax log
Hi
Please follow the steps to print the fax log
To print the fax log from the device control panel
1. On the device control panel, press Setup.
2. Press the arrow key to move down to Print Report, and then press OK.
3. Press the arrow key to move down to Fax Log, and then press OK.
4. Press OK again to print the log.
Oct 29, 2010 | HP Officejet 6500 Wireless All-in-One...
I cannot seem to get the fax confirmation report to print after sending a fax HPJ4580
Did you turn it on? http://h10032.www1.hp.com/ctg/Manual/c01368573.pdf
PDF page 64 (manual page 60) give instructions on how to turn it on all the time or how to print a fax log report.
Carl
Mar 31, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do i get my HP Officejet 6500 to print fax confirmations
In the main menu, under ''Fax options'' choose to print journal report at end of fax transmission. This may also be termed a transmission report. Thank you, Dana
Nov 09, 2009 | HP Officejet 6500 Wireless All-in-One...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 6210 All-in-One - Conformation Page
yes
press setup
pres 2 and then press 1
this seletcts print report and then select Fax Report setup.
press and scroll to the to the report type you want.
press OK to select the report
Jan 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
280 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
