Question about Vizio SV470XVT 47 in. LCD TV
Hi! my lcd samsung ln-3242h has a graphic problem...everything on TV has trailing images (or ghosting like effect) when it's moving..this happened all of sudden but I think it might be related to power surge (like the cord got accidentally pulled off and the TV got turned off).. I don't know if it's the mainboard problem, LCD/plasma problem, or graphic problem...please help
    Top Expert:
  • Vizio Master
  • 12,962 Answers
T con board is responsible for image on screen as well as any anomalies present.
Posted on Sep 04, 2017
SOURCE: my lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know!
Posted on Aug 21, 2009
SOURCE: I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
Posted on Dec 06, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here :
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 501 Answers
SOURCE: i have a sony 32'' lcd flatpanel bravia tv . the
check yr aerial,ghosting is caused by signal reflections off say,chimnets,buildings
Posted on Jul 01, 2010
  • 821 Answers
SOURCE: LN-3242H Will not turn on
Hello,all you need to do is to get another fuse or IC to replace the faulty one,if that is done,you will have your television functioning as supposed.
if the problem persist,please feel free to contact us here.
take care.
Posted on Dec 02, 2010
Scrolling ghost bar on Samsung LCD TV
Majority of the time when you get a soft type of scrolling or distortion it is a poorly made cable or connector causing bad signal. I would replace that RCA cord altogether and go to the top end with and HDMI cable. If this is not an option buy a newer upgraded version of the RCA cable. The ones that come with everything are only really good for in a pinch
Jan 29, 2014 | Samsung Silver Tilt/Tilting Wall Mount...
I have a samsung lnt4071fx tv. The picture is really messed up. Is it possible that it is a loose connection or is there a known problem associated with the following symptom: picture gets dark,...
As we discussed in chat session, apparently it is problem of lcd panel (screen) that will be replaced to solve tv problem however t-con board, that is part of lcd panel, replacement might solve picture trail problem.
Click for required t-con board.
Apr 03, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Samsung LN52B750 LCD TV image smear/trailing
It transfer the universal image signal of TTL and LVDS signal to specific TFT LCD.
No offense, but it is a very complex subject.
Unless you're an EE.
Apr 09, 2010 | Samsung LN52B750 52 in. LCD TV
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Samsung LCD TV Image Retention...I Think
I have not noticed that with my set, Sony Bravia 2007 1080I.
Uh, I have a bigger problem though...
I had just paused my live tv for about 40 minutes on abaseball game and now I have green burn in.
I'm in the middle of searching the net for solutions. I have tried:
pure white screen for 30 minutes (no change)
"fuzz" for 1 hour (no change)
turn TV off for 12 hours (no change)
I'll now try to power down fully for 12 hours and see what happens.
Apr 26, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Vizio SV470XVT 47 in. LCD TV Logo
59 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
