Question about Dometic Rooftop RV Air Conditioner
Was given a roof top ac for a popup camper need help
Was given a roof top ac for a popup camper andwas given a roof top ac for a popup camper and need to hook up to 115 volt it has 6 wires red black white yellow green and blue can anyone please help
  • Dometic Master
  • 6,674 Answers
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Posted on Aug 02, 2010
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
We have a 1997 Coleman popup camper. The air is just a little cool and it keeps leaking on the inside. I called a repair place and was told it was most likely low in freon and that it could not be added...
the drain is blocked and needs a clean out ,look for a drain hole with a pipe to the outside .as for the gas recharge then yes it can be filled by a specialist and not a chancer ,you have to cut a pipe on the motor and solder a connection on the end not a problem for a experianced person
Jul 25, 2013 | Heating & Cooling
I need the threded rod assembly that cranks up the hard top on my coleman popup camper 1994 i think
IF YOU HAV THE OLD 1 . CHECK AROUND TO YOUR LOCAL CAMPER , OR MACHINE SHOP OR WELDING SHOP, IT MIGHT BE REPAIRABLE.. IF NOT CHECK THE WEB FOR CAMPER CLUBS OR FORUMS .. JAY
Jul 23, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
Pop up camper-leaking from ac unit when it rains.
Personally I would undo the 4 bolts that hold the upper unit (outside) to lower unit (inside) , then with circuit breaker off & confirmed that no power to it, take cover off for hydro connection, and unhook those wires, and unclip harness from connector to upper unit, to allow for removal of the lower & upper unit, then remove both upper & lower and cover the hole for now until you decide on whether or not your going to fix the roof supports in that area. I'd cut a 16" square piece of painted plywood or fairly stiff aluminum, add a good thick bead of sealant (not silicone, it doesn't last long) to the area where you see the gasket was seated & screw the cover right to the roof for a temporary fix. Make sure you attach screws close to where gasket would be under your cover, (about 1"-1-1/2" in from edge of 16" cover) so that the holes will be covered later when AC unit put back on, by the gasket of the AC unit. Make sure you put maretts back on hydro wires & add some electrical tape over them as well to keep maretts on while traveling for now. Don't know how handy you are, but fixing that over the winter may not be as bad as you think. If you need advice later, get back to me/us.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Leaking palomino popup trailer
improper sealing around ac if no ac the molding that runs down the center or around the perimeter of the roof do a search on rv leaks on you tube this will help you on your quest also in my personal opinon i would trade the unit cause two years or water damage you are going to have mold in the unit so just get rid of it
Jul 09, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Cracks in the top
nice solution should work, and yes bad design by coleman. you can also paint roof with camper roof paint silver with fiber
Jul 07, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Replacing the ''wood'' in the top(ceiling) of a pop up camper. Cant seem to find a correct listing for this in the menu.-----------but this is for a Tracker pop-up camper. It started leaking around the...
i would suggest getting a price on the entire roof assembly from a dealer depending on age these roofs can be lminated togehter ang removing the skin car cause strustural damage to the camper roof it is common practice to stop the leak remove most of the wet wood and overlay what is left standing sounds bad but only way to fix cosmetcally if you need to soarce parts do a search for all right manufacuring they supply celing and metal for most camper manufacures
Jun 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
AC unit on Viking popup is loud and vibrating
take the cover off the front of unit and look down inside at the blower wheel see if there is something in it
Jan 22, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
344 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
