Question about Acer Computers & Internet
Hello, I have an Acer Aspire 5532 and the battery died while it was unplugged. Usually I just plug it up and press the power button and it will ask if I want to load Windows (normally, safe mode, etc.). I usually load the normal Windows and it takes me to the User page so I can log onto my user profile, but now I just get a blank screen after it displays the Windows logo.
    Guru:
  • Acer Master
  • 468 Answers
Try the below steps:
Shutdown the computer and Restart it, as soon as it restarts keep on tapping F8 key, now select, "Last Good Known Configuration" and hit "Enter" key. It should take care of the issue. If not, then boot the computer to "Safemode", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode" from the Advance boot menu. If it is booting to Safemode, then perfomr a system restore to previous date. If nothing happens, then you have to perfomr a full system restore.
Posted on Jul 31, 2010
ACER ASPIRE 5532 RECALL
This is more than likely. Your local computer repair shop will be able to advise.
Feb 12, 2015 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My acer aspire 5532 just went black. The power button goes on' but no response whatsoever. Any clues?
Just try this steps
1) Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button
2) Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
3) Load BIOS setup Default
4) Try to go to safe mode
5) Do system restore when your computer was working fine
I hope this will answer and fix your issue
Regards
MAJID KHAN
Nov 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Acer aspire 5332 plugged in but not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.If it doesn't work, the most likely cause is the laptop charger. Use a new one to confirm:
Replacement Acer Aspire 5332 AC Adapter 65Watt 19V 3.42A
Oct 23, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Acer 5532 Touch Pad Not Working
Here are a couple of ideas from a Google Search:
Press the key to the left of the On/Off button. The key has a picture of a finger pressing the touchpad. So simple, so elegant, so little information out there about it.
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/my-touchpad-on-my-acer-aspire-5532-laptop-isnt/51f5de30-b465-e011-8dfc-68b599b31bf5?auth=1
Dec 23, 2017 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Aspire 5532: touchpad no longer works, machine works fine using mouse plugged into USB. What can I do to make the touchpad work again?
Hello Egor,
This model has a touchpad lock. May you inadvertedly locked the touchpad.
Anyway, it's so easy to unlock it. Simply press the 'finger' button which is found on the left of the power button and that should make it work again.
Hope this helps you.
Sep 01, 2011 | Acer Computers & Internet
Is there a mute button on an Acer Aspire 5532?
From memory, there usually is a FN button and an F button to press.. such as FN (near windows key) and F1 to F12.. they have little images on them,,.one should look like a speaker.
Feb 19, 2010 | Acer Aspire One PC Notebook
My laptop acer aspire 3100 crashed. it was fine before i turned the laptop off, but when I tried to turn it on again it got stuck starting windows up, I have Vista. I waited for some time but after 30 min....
Hello rijotomas,
First you can try to pull the battery out and unplug the power adapter for a minute. Then plug the laptop back in without the battery. Then try to turn it back on.
Feb 23, 2009 | Acer Aspire 3100 Notebook
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
My acer aspire 4520 would also just turn off by itself without warning. i usually remove the battery, put it back in and check with the charger. usually it doesnt boot up either, i have to guess or...
DO A POWER RESET.
take out the battery unplug the power adapter, then hold down the power button for 30 seconds.
after youve done that plug the ac power adapter in leaving the battery out.
press the power button.
after successful power up shut down n insert the battery.
Dec 09, 2007 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
