Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Psp won't power up on mains or battery - Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 211 Answers
Buy a new battery!
Posted on Aug 17, 2010
I have just received the psp-1001 from a friend, the battery is fully charged but it won't turn on, is it a lost cause?
Better bring it first to some PSP tech to verify the problem of the board, some micro fuses might have blown.
It takes some soldering to replace it
Hope that helps you!
Oct 02, 2011 | Sony PlayStation Portable (PSP) Console
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Psp green light on, but no booting or anything. its not a fault of Software... its Hardware for Sure! any help?
Hello
If the green light comes on, but the unit won't power up, you could have a battery problem.
Clean out the battery compartment. Use a can of compressed air to remove dust, hair and other debris. If you left the battery in while you stored the unit, look around the connectors for any sign of corrosion that could be affecting the connection.
Plug the PSP into the power adapter with the battery still inside. If this doesn't work, remove the battery and see if the PSP powers on with the adapter only. If it does, then the battery likely needs to be replaced.
Boot the unit in recovery mode. The PlayStation Portable is like a small computer with a tiny hard drive. And just like a computer, sometimes it gets scrambled; booting in recovery mode can help you identify or correct the problem.
Determine if your PSP has been "bricked." If the PSP was turned off for any reason during a firmware update, it can cause "bricking," so named because it renders your PSP into a useless, plastic brick. Buying a new PSP or sending yours to Sony for repair are your only options if this has occurred.
Jun 10, 2011 | Video Game Consoles & Games
Psp power up green lights on black screen after a few seconds shuts down psp slim
it sounds like you bricked you psp, if it's not a 3000 or psp go you can probably fix it by buying a pandora battery and magic memory stick.  you can buy them from here http://pandorasales.com/?gclid=CNLk1fzUzqgCFcO8KgodAzI2lA , if you are running a psp 3000 and up, you could try to format your memory stick but it probably won't work.
Apr 25, 2011 | Sony PlayStation Portable (PSP) Console
When i switch on the psp,the power led(green led is seen,but nothin is seen,and when i try to switch off the psp the green light stays as it is and only removing the battery will turn the psp off..soo is...
have you tryed to put the main power cord in and see if it will boot as normal ?
some people have modded psp and there battery could be a parnora battery need for modding psp that will give you the green power light and blank screen
also take out any memery stick
and try
what is your firmeare numbers / letters ?
Sep 29, 2009 | Sony PlayStation Portable (PSP) Console
Psp power failure
maybe the main problem is the battery, change your old battery and buy a new one. thanks
May 26, 2009 | Sony PlayStation Portable (PSP) Console
Psp slim won't charge
maybe the main problem is the unit or the battery itself, go to the sony repairing shop so that they can replace it or fix it. thanks
Mar 29, 2009 | Sony PlayStation Portable (PSP) Slim...
Charging a PSP
Sounds like it could be the mains/charger of the psp, have u tried using it on the other psp? If that dont work then it may be the power charging unit of the psp itself, u may have to call Sony and have it replaced
Hope it helps
Z33m
Dec 10, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
