Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Putting filter back together
Help me
    President:
  • 1,673 Answers
Maybe this picture will help:
Posted on May 26, 2008
I took the filter out of my Windtnnel Pro Pet to clean it (not with water) I put it back in and now the vacuum wont turn on.
I'm going to guess that when you put it back together it didn't quite go back in correctly. There could be a switch that prevents it from turning on if the filter is not installed. Make sure that it is seated correctly. I hope thats all it is.
Dec 27, 2014 | Tti Hoover 4010100Y 3-Pack Type Y...
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Filter whistle noise
Hi Basil,
I am sorry to hear your machine is emitting a high pitched sound. Based on the details you provided the problem may be isolated to the post motor filter, if so a new filter will be needed. We would like to help with this. Please contact our Helpline to speak with an expert:
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Sep 01, 2013 | Dyson DC25 Vacuum
Took top filters out and forgot how to put back together
erepacementparts.com has schematics for ordering parts. enter model # and look at diagram should give you a visual of how it goes together
Feb 04, 2013 | Vacuums
No suction in upright vacuum.
it could be the filter or on this unit, one of the other 2 filters. The most common overlooked filter on this unit is the filter in the pull out tray under the bagless container. I would suspect that is the culprit cutting off your suction. Pull it out and wash the filter, wash the other 2 filters in your unit as well. Warm water and soap, little bit of bleach to kill the smell and LET THE FILTERS DRY BEFORE PUTTING THEM BACK INTO THE UNIT. I cannot stress that part enough.
Good luck!!
Jan 24, 2012 | Bissell 3576 CleanView II Bagless Upright...
Filter Queen Assembly
On the rubber piece, there is a groove on the inside edge for the screen first, then the filter. Just have to work them into that slot. Then put over the bottom housing. The round paper filter is put on over the tank, then the top unit sits on that. These filters will keep dust out of the motor and head asm.
Mar 18, 2008 | Vacuums
Hepa filter does not rotate
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Mar 16, 2008 | Hoover U6630-900 WindTunnel Bagless...
Prolem putting parts together
Heres the link to the manual
newzealand.bissell.com/images/UserGuides/6594.pdf
Nov 19, 2007 | Bissell 6594 PowerForce Bagless Upright...
HEPA Filter
It maybe that the filter is in need of replacement. They need to be changed once a year.
Sep 13, 2007 | Hoover U8311900 WindTunnel 2 Vacuum
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
