Question about Whirlpool Refrigerators
WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
HOW TO REPLACE THERMOSTAT
    President:
  • 1,099 Answers
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Posted on Jul 30, 2010
Ice lump build-up on left side of the lower back panel inside the fridge section of fridge freezer. Compressor is on continuously. Any help appreciated. Thank you.
Check the operation of the thermostat. Try raising the temperature og the refrigerator side and see if the compressor stops.
Oct 30, 2017 | Whirlpool Refrigerators
My kenmore coldspot mode 106.53394300 is freezing items in the fridge
If further adjustments cannot be made to the thermostat, the next step would be to replace the thermostat or if so equipped, the temperature thermistor.
Jan 30, 2015 | Kenmore Refrigerators
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Have model WB 325 (201 litre) fridge / freezer. The fridge is not as cold as it was since we moved. Wondering what can be the problem. Fridage is approx 2 years old.
Check the back for the cover over the service opening This has to be in place.
Sometimes when you move it gets torn off.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 05, 2011 | Whirlpool Refrigerators
Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Aug 16, 2009 | Whirlpool Refrigerators
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The Fridge stays too cold at -6.
Yes it is the thermostat. Replace it or have it replaced.
Jun 13, 2008 | Freezers
Refrigerators Logo
192 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
