Question about Lexmark Wheelwriter 1500 Typewriter
Lexmark1500 typewriter the typewriter is in "envelope" mode how do I change it to forms, etc.
  • Lexmark Master
  • 3,594 Answers
Goto lexmark.com, click on support, poke around you will find a downloadable manual there. A picture is worth etc.
DickyO
Posted on Jul 30, 2010
How do you repeat what you have typed. I want to do a bunch of envelopes with out having to type it all over again when I put another envelope in the type
The action writer dosen't have a memory, You need a Wheelwriter with store,play and delete keys down the L. side of the keyboard.
DickyO
May 16, 2012 | IBM Actionwriter 1 Typewriter Made In...
Format change
Go to lexmark.com, click on support, poke around you will find a downloadable manual there.
DickyO
Jul 30, 2010 | Lexmark Wheelwriter 15 Series II...
Cannot reset margins, especially left.
Return to L. margin Press & Release Mar REL key backspace or space to desired location, press L. margin key. R. mar. works the same.
DickyO
May 10, 2010 | Nakajima AE-710 Typewriter
Need a new typewriter ribbon
CONTACT www.inkribbonpaper.co.uk. They have the ribbon for your brother 800 deluxe. i bought from them recently
Jan 14, 2010 | Brother Office Equipment & Supplies
Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Label, envelope and phr lights flashing.
Check the connectors between the keyboard and PC board.
DickyO
Apr 10, 2009 | Lexmark Wheelwriter 3000 Typewriter
I have a brother electric typewriter and the print on the paper is no longer sharpin appearence.I changed ribbon to no effect.Now what?
MAKE SURE RIBBON IS INSTALLED CORRECTLY, SHOULD BE BETWEEN "FINGERS" NEXT TO CARDHOLDER AND CARDHOLDER.
COULD BE A BAD BATCH OF RIBBONS
SOMETIMES CORRECTABLE RIBBON DOESN'T PRINT WELL ON CERTAIN TYPES OF PAPER, SUCH AS "NCR" PAPER, TEXTURED, SLICK OR ANY PAPER THAT HAS BEEN THROUGH A PRINTING PROCESS (FORMS, LETTERHEADS, ETC.)
CHECK RIBBON ITSELF. THE CARBON SHOULD BE A FAIRLY EVEN LAYER. IF THERE ARE BLANK PLACES----
Dec 03, 2008 | Swintec 7040 Typewriter
HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Jul 29, 2008 | HP Officejet 6310 All-In-One InkJet...
Nakajima AE710 typewriter
The forms obviously have a glossy surface, a fabric or multi strike ribbon will work. There is a impression control oh the l. side of the keyboard and also a bold feature, try max impression and bold.
DickyO
Mar 27, 2008 | Nakajima AE-740 Typewriter
IBM wheelwriter 1500 by lexmark
Press and hold the code key and the label key this should reset it.
DickyO
Nov 30, 2007 | Lexmark Wheelwriter 3000 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
