Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not spin. The motor is humming but the tub will not spin.
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Have a whirlpool duet washer and when it spins it makes a load whirling noise
main bearing for tub or motor, neither is cheap. motor can be changed by homeowner, but the tub bearing is a major repair. get an estimate from someone, may be time to replace
Jan 08, 2012 | Whirlpool Washing Machines
My Whirlpool GHW9100LW1 washer stopped working
be sure that the tub is moving around with out the outer tub moving....could be a motor controller problem.....but heres the part#s tub assembly#8181912 youll want to replace the seal too. seal#8181673
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a Whirlpool LA6800XTWO washer. When I run it, it fills with water, but it does not spin, agitate, or pump the water out. When it gets to a point that it should do one of the above things all I...
sounds like a broken coupler, looking at your wiring diagram this unit would agitate with lid up right? then lid sw is not your problem, if it does not drain either then motor must be not turning over, so i would check the capacitor first. (it on the back panel behind the tub)
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LA6800XTWO will not drain or spin
Need a new drain pump. I just had this problem. found a drain pump on ebay for 60. Replaced and running mint again. don't keep trying or you will burn out your motor.
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Whirlpool duet washer wont run
sounds as if perhaps the hummm is coming form the drain pump not the motor, remove the front cover and you ll be able to acess the drain pump resivior, unscrew it and you find all sorts if things jammed into the pump preventing free spinning, 7 years servicing this unt never saw a bad motor, 1000's of pumps
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tub spins too fast on all cylces
Just wondering: did the technician also replace the motor control unit? Or is that the 'spin unit' that you mentioned?
See pages 4-7 and 5-4 in the repair manual.
http://adcxns1.whirlpool.com/Service...0Job%20Aid.pdf
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
