Question about Amana ABD2233DES Bottom Freezer Refrigerator
My freezer door will not close properly - Amana ABD2233DES Bottom Freezer Refrigerator
    President:
  • 1,099 Answers
Sometimes, just smearing vaseline all around your gasket on your door will help to seal it. We do this as the gasket dries out a little. Also, you might check down at the bottom where the door washers, etc. are, and see if that is part of the problem. I have had both of these problems and this seems to have taken care of it.
Also note that
A huge block of ice has built up behind the back panel. This has made the back panel expand, thus making the drawers jut out too far. Like me, you may not think ice build up is the cause, since you cannot see any ice.
Action: Defrost freezer. Yes, I know its frost free, but wait an see! Take out al drawers, empty fridge and freezer and defrost overnight with doors open. The next morning, unscrew the back panel of the freezer. You will see 4 screws, 2 at the top, 2 at the bottom. These are not normal screws and are in an awkward postion at the top. Use pliers to grip and unscrew. Slide the panel forward and out. There! A massive block of ice! YOu will also see a hole at the bottom. SO that this didn't get blocked with all the water, I plugged the hole up using a ball of tissue wrapped in some plastic from a plastic bag (clingfilm would also do the trick). Use a hairdryer to melt the ice. Do not chip away at the ice as this might do damage. It took mine about 20 minutes to melt until a large block could be safely removed. Once you have dried the inside, unblock hole and screw panel back on. The drawers should now fit and the door close. I found I still needed to give my door a little help with closing it, but it did close and seal fully. All you have to do now is turn the fridge freezer back on.
But if the door gasket is bad you can change for a new , the follow is a guideline for you to replace
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
Step 2
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Step 3
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Step 4
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Step 5
Keep the gasket clean to last longer.
Check the seal by closing the door. You should have a nice, tight seal.
Hope this helps
Posted on Jul 30, 2010
Subzero refrigerator/freezer, model 590. Door gaskets replaced last year, but it still ices up in top front of freezer? Any ideas?
Ice or frost in the freezer can be caused by one of Three issues:
    • An improperly closed door.
    • Improper ventilation of the freezer.
    • The Ice Maker Flap.
    1. Door Not Closed Properly
    • Make sure that the freezer door closes completely.
    • Make sure that the door gaskets are attached properly to the door and that they are clean. Also, make sure they are sealing properly and are not torn or split.
    Take a dollar bill and close it in the door. If you can pull the dollar out with no resistance, the seals should be replaced.
    • Make sure there are no packages resting against the rear wall of the freezer.
2. Improper Ventilation
    • Space your food out as much as possible to improve ventilation.
    • Make sure that the air vent in the freezer is not blocked.
    Refrigerator Compartment
    If your refrigerator is freezing food, the temperature is set too low. Raise the temperature a few degrees to fix the problem.
    If your refrigerator temperature is too high, condensation may build up and freeze on the bottom of the refrigerator. Lower the temperature a few degrees to fix the problem.
Dec 06, 2016 | Refrigerators
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
I always have icicles in the freezer and anytime we close one of the doors the other comes open and then closes again
Door gasket defective, check for proper seal around door (gasket should be flush against frame when door closed). Also other possible cause is that when you close the door to the ref, the freezer pops open just enough to cause ice to build up around door. Check drain plug inside evap area of freezer, and repalce door gaskets.
Oct 01, 2009 | GE GTS22WCP Top Freezer Refrigerator
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
How do you level the kitechenaid side by side
Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Amana ABD2233DES Bottom Freezer Refrigerator Logo
248 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
