Error 53.21 hp color 5550 - Office Equipment & Supplies
    Novelist:
  • 170 Answers
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Posted on Jul 30, 2010
  • 3 Answers
SOURCE: 59 C0 error on hp color laserjet 5550
I had the same error, I had to take the left side cover off, (looking at the front of the machine) and found a small piece of paper that ended up right in the middle of a sensor flag! Of ALL the places to land. I pulled it out, it worked, end of problem! When you get the side cover off, the sensor flag is located in the middle/bottom of the printer. Hope this helps, happy fixin'.
Posted on Sep 08, 2008
  • 61 Answers
SOURCE: user error
FUSER ERROR:
. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Posted on Mar 27, 2009
  • 311 Answers
SOURCE: HP color lasejet 5550 dn does't print.
hello
You could try with different cartridge try to clean the contacts , check wether the cartridge is seated properly , make sure weather the strip is removed from the cartridge
OR
If you use a HP original cartridge, then you shouldn't have this message.
Anyway you can print, it's only at startup that this message appears.
If it is a HP toner, then change it.
Or
try this link and you will find answers for all your printers errors
http://www.all-laser.com/cgi-bin/webc.cgi/error-code.html
Posted on Mar 05, 2010
SOURCE: I have a 59.30 error code on a HP color laserjet
i have a 59.30 error code on a hp clj 5550
Posted on Mar 23, 2010
  • 75 Answers
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
Posted on May 10, 2010
Error code 59.61 on hp color laserjet 5550
Book says that it is the cyan drum drive assembly that needs replacing. Part number RG5-7723-000CN.
DO NOT attempt to do it yourself. A tech needs to do it.
Feb 19, 2015 | HP LaserJet Office Equipment & Supplies
Have a 59.30 error code on a hp clj 5550
My printer displays a 51.23 error, what to do? hp laserjet pro cm 1415fn color mfp
Oct 09, 2013 | HP Color LaserJet 5550hdn Printer
Sir, i have a hp clj 5550 printer acept cyan all other color printing
Check the black clip on cover on top of the paper pick up assembly under the cyan cartridge.
If it is not fitted correctly cyan will not print and no error message will be displayed.
Aug 17, 2011 | HP LaserJet 5550 Printer
HP Color LasrJet 5550 dn Error code 59.30
The error says that the printer has a "fuser motor startup error".
Not a good error to get.
Possibilities are a bad fuser motor, bad DC Controller or fuser drive assembly.
If you haven't already, power cycle the printer.
If the error persists, you are going to have to have a tech look at it.
Feb 28, 2011 | HP LaserJet 5550 Printer
I have a error code 59.30 on HP laserjet 5550
here is the solution for your hp color laser jet 5550 printer
fbd1ddf.jpgThis will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | HP Color LaserJet 5550hdn Printer
How do you resolve 59.30 error code on HP color laserjet 5550
finally i solve this problem hp colorlaserjet 5550 error 59.30 same with an error 59.40 ERROR this is occurred with the fuser motor during startup or not rotating. take the left cover off and replace the motor. hope this will help.
Jun 09, 2009 | HP LaserJet 5550 Printer
Eror message 49.4401 on hp clj 5550
Dec 15, 2008 | Office Equipment & Supplies
405 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
