Question about WYSE S10 (90210501) Network Terminal
When i login to the WYSE I get an error PN agent sign on failed
Need to know what diagnostic code po 106 on my 2004 harley-davidson nightrain
P0106 = MAP sensor rate-of-change error
P0107 = MAP sensor failed open/low
P0501 = VSS sensor low
P0502 = VSS sensor high/open
Jun 14, 2012 | 2004 Harley Davidson FXSTB - FXSTBI Night...
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
Wyse v90l
Best thing to do here is a re-image the client using the tools on the Wyse website.
The new USB imaging tool is pretty handy at imaging this model, and should get this back to a default image and working very quickly :)
Jan 14, 2009 | WYSE V90LE Thin Client VIA 1.2GHz, 1GB...
Wyse 3125 CE
when the terminal is logging of select ctrl-alt-esc and it will come up with login screen where you can just login as administrator
Nov 14, 2008 | WYSE V90 Network Terminal
Wyse PXE boot error
All Boot devices in BIOS may need to be set to "NONE". When shutting down, select "Shutdown and Restart the system, then hold the "Delete" key down while clicking the OK button. Keep holding the "Delete" key until system restarts in setup. Password that I was given is "Fireport". If that gets you access, then set all boot order configuration items to "NONE", then "Save Values and Exit". Hope it works for you as well as it did for me.
Feb 08, 2008 | WYSE S10 (90210501) Network Terminal
Reflashing wyse s30 unit
It probably has to do with the version of CE client that is installed on the Thin Client. I have run into this problem before. The same Wyse clients can have different versions of CE installed. If the versions are the same then contact WYSE tech support to find what the error code relate to. BPCS
Dec 08, 2007 | WYSE Winterm S30 Network Terminal
WYSE S10 (90210501) Network Terminal Logo
756 people viewed this question
Top WYSE Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Edward Greene
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
